Old 07-19-2018, 06:47 AM
speed-racer speed-racer is offline
Default RV 6 TO A RV6A
I just bought a RV 6 and am not really comfortable with the whole taildrager thing. any one ever convert a 6 to a 6A, any thoughts and advice is appreciated.
Old 07-19-2018, 07:07 AM
Sam Buchanan's Avatar
been here awhile
Two suggestions:
1) Either get more training so you can be "comfortable" with your RV-6
or
2) Sell the plane and buy one with a nose gear.
Converting the -6 to a -6A is a major job for an RV builder and a totally impractical one for a non-builder. The money and time would be better spent on moving to a different aircraft.
Your best choice is most likely the first one. Find a good instructor to get you up to speed on the RV-6 and you will find you have a delightful aircraft.
Welcome to VAF, Tony!
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Carl Froehlich's Avatar
Interesting. I know of a person buying an almost complete RV-6A and is trying to convert it to an RV-6 (against the advice of all previous RV builders he has talked with).
Iíll send him a note - perhaps a fusleage swap is the path forward for you.
Old 07-19-2018, 07:11 AM
been here awhile
It would have to be an airframe swap, the wings on the sixes are unique to each fuselage. Not practical.
Sam Buchanan
1999 RV-6
Old 07-26-2018, 03:49 PM
txshan130 txshan130 is offline
I second the learn to fly it option! I had zero hours of TD time when I got my - 6. Love it and wouldn't change a thing!
Brian Shannon
Katy, TX
RV6 N7463B
Old 07-29-2018, 07:04 AM
flyinhood flyinhood is offline
I would also suggest getting quality tail wheel instruction. You may need to travel, but it is totally worth it. I would estimate the cost and time required to get comfortable and master the tail wheel would be exponentially easier than trying to modify your 6.
I have helped many pilots learn and 10 hours and 60 laps in the pattern is not unheard of. I would also suggest you get comfortable with wheel and 3 points. Chances are you will prefer one over the other. I see some on flight reviews who only use 3 points and are almost dangerous attempting wheel landings.
One of the best compliments I received was a wide body capt. returning from an asia trip commenting that he can't wait to get to the airport and enjoy some more tail wheel.
I think I have read / own every tail wheel book and this is one of my favorites:
https://www.amazon.com/Conventional-.../dp/1560274603
It really is fun and rewarding after you get the hang of it!
46 Luscombe 8a Rag Wing, Armstrong starter
RV-6, IO-320, Catto, G3X Panel (Thanks Walt!)
Old 07-29-2018, 07:47 AM
Ahh, the (original) 8A. Mine had been metalized. I learned to fly in it; a great teacher. Went straight from the Luscombe to a Thorp T-18, & had no problem at all. (For the uninitiated, the T-18 is a bit hotter than an RV-x.)
I'd also advise to at least give it a try with a good t/w instructor before doing something more radical. But if you must drag your nose, you can convert it without either a fuselage or wing swap (??). All you need is the motor mount, main gear mounts, and the gear itself. (And a lot of time & misc hardware, of course...)
Charlie
Old 07-29-2018, 07:59 AM
wilddog wilddog is offline
Arenít the landings in an -A similar to a tail wheel in that you must keep weight off the nose gear? Taxing would be different but on landing on grass, the nose wheel can dig in and needs to be held off as long as possible. Just my observation, never flown a RV-A, only taildraggers so take this for what it cost.
Old 07-29-2018, 08:08 AM
Sorry; no. A trike has cg forward of the mains; a t/w a/c has it aft of the mains. You think it's stable because you don't think about correcting for the instability.
Old 07-29-2018, 08:09 AM
Mel's Avatar
Mel Mel is offline
Originally Posted by wilddog View Post
Aren’t the landings in an -A similar to a tail wheel in that you must keep weight off the nose gear? Taxing would be different but on landing on grass, the nose wheel can dig in and needs to be held off as long as possible. Just my observation, never flown a RV-A, only taildraggers so take this for what it cost.
This rule applies to ALL nose draggers. Not just RVs. The nose wheel is for taxiing. Not take-offs and landings.
A&P/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
