Old 07-16-2018, 12:51 PM
kbalch's Avatar
kbalch kbalch is offline
Default Rudder stops...
Let me preface this query by saying that I'm not an inexperienced builder and yet...
I'm having difficulty fabricating the rudder stops to my satisfaction. I already managed to screw up one half of the first pair on the last cut, so I ordered another of the "raw" drilled angles from Van's - my first extra part of the -14A kit.
The current plans (ever so much improved over the old -8 plans, though I'd love to have a combination of the -8's highly detailed drawings with the -14A's step-by-step instructions) show only two drawings of the rudder stops; it would be useful to see a dimensioned drawing of each face of the part.
Can anyone point me to something like that? Even a set of photos of each face would be useful.
Other than that, the project is moving along. VS, rudder, and HS are done (less the glass tips), elevators and trim tab will be done this week (foam ribs are up next), and the tailcone is nearly complete. Wing kit should be here in the next day or two. Progress!
Ken
RV-8 N118KB (sold)
RV-14A #140494 (Finish kit in progress)
N114KB (reserved)
Old 07-16-2018, 01:22 PM
bkervaski's Avatar
I couldn’t get them to my liking either so I switched to the flyboys internal stop.
Progress: Flying!
Old 07-16-2018, 01:37 PM
Chris Cooper Chris Cooper is offline
Mine aren’t perfect but here they are towards the bottom of the page on my blog:
http://www.vansrv14.uk/index.php/201...0-01-to-10-04/
Chris Cooper
RV14 - building
www.vansrv14.uk
RV3A - bought
Old 07-16-2018, 01:53 PM
RV-14E's Avatar
RV-14E RV-14E is offline
Page 10-04 has the dimensions called out with a scale diagram from top, side and oblique.
Click here to see how mine came out.
E
http://rv-14a.blogspot.com/
Old 07-16-2018, 02:39 PM
kbalch's Avatar
Thanks, gents.
I've printed each of those photos and will cogitate on them tonight and attack the angle in the morning. Clearly marking the bits to be removed is a good machinist's habit and I didn't do it on the first attempt. No excuse.
Time to go put the snap bushings in the tailcone...
Ken
RV-8 N118KB (sold)
N114KB (reserved)
Old 07-16-2018, 06:25 PM
mturnerb mturnerb is offline
I did it twice. Kept visualizing over the drawing in the plans. It helped to have the "bad" version in hand to avoid the same mistakes. It is REALLY hard to cut through the corner part of the angle - go "wide" and work it down!
Turner Billingsley
RV-14A FLYING!!
Old 07-17-2018, 12:09 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Good idea for making mirror imaged stops for left and right. What you may find, however, because the vertical stabilizer is offset to one side, the stops will end up having to be sized and/or shaped differently from each other too. My recommendation is to make them a bit oversized, cleco to the fuselage, then file down as necessary to get the required travel on each side separately before riveting them on.
Hope this helps. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2020
Old 07-17-2018, 06:40 AM
kbalch's Avatar
Silly question, but is there any good reason to do the stops now vs. once the tail has been mounted and the actual rudder travel limits can be measured/visualized?
Ken
RV-8 N118KB (sold)
N114KB (reserved)
Old 07-17-2018, 08:47 AM
RV-14E's Avatar
I don't see any impediment to that approach. Bucking access is still available, though you might bop your head on the horizontal stab. I ultimately (re)attached my rudder stops because I replaced my F-01412 Aft Bulkhead, explained here.
Keep in mind that the plans seek to accommodate desired rudder travel by offering you the opportunity to remove material from the rudder stops or add material to the rudder horn, as explained on pages 11-09 and 11-10, respectively.
E
