Old 07-20-2018, 03:46 PM
airguy's Avatar
airguy airguy is offline
Here's what I ended up doing, I took the air off the back of the #3 cylinder baffle, routed it forward right up against the cowling to the heat muff on #1, then the heat muff discharge is nestled up against the sump/block to come back aft to the heat door. It was a little interesting getting it in there but that's the only way I could get it routed with what I considered to be acceptable clearance from the exhaust heat.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 400 hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 07-20-2018, 04:11 PM
sglynn's Avatar
sglynn sglynn is offline
Default Scat Tube Run
I just finished my Scat Tube run with IO360 on RV-7A. Photos are here.
http://www.mykitlog.com/users/displa...=248211&row=12
I put stand-off heat shields on my exhaust pipes to protect scat tube from their heat.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
