Old 02-12-2017, 06:02 AM
mturnerb mturnerb is offline
Default Tip: Using nutplates to on elevator counterweights
Based on a few threads where people had issues with loose counterweights (and suggestions to use floating nutplates to fashion a better way to tighten them), I decided to make a couple of retaining plates for my elevator counterweights. I used floating nutplates and some scrap aluminum. I like the way it turned out. Too late to do similar on the rudder, hoping the locktite will do the job there.
https://www.dropbox.com/s/cb8hu9lo4t..._3208.jpg?dl=0
https://www.dropbox.com/s/2bomuprvi7...81%29.jpg?dl=0
Turner Billingsley
RV-14A FLYING!!
Old 02-12-2017, 02:53 PM
RV7ForMe RV7ForMe is offline
Default Great!
Looks good. I have been thinking about this as well. I am just a little unsure if this adds weight? did you shave the led for whatever the difference is from your setup and the 2 jamnuts? would it make a difference?
what are other cons? I am just trying to be very careful when changing from the plans...
VAF dues paid until 10/2019
RV7-A (N137MX Reserved) - Empennage 95% done
RV7-A (N137MX Reserved) - Wings Started...
RV7-A - Rebuild Done.
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 02-12-2017, 03:23 PM
The amount of weight is pretty minimal. I attached the elevators today and they are a little out of balance with each other so will need some adjustment later on. But adding the weight of the two small pieces of aluminum plus two nutplates (and a few rivets) on each side (less the weight of nuts and washers replaced) is very small. No more than a few grams.
Turner Billingsley
RV-14A FLYING!!
Old 02-12-2017, 04:45 PM
I see. I guess final balancing is done after assembly and paint? how does one change or fix any unbalance with the rudder with the led being riveted in a place with no access?
but in general I think it makes a lot of sense what you are doing.
Old 02-13-2017, 06:04 AM
Not sure when final balancing gets done - haven't gotten that far along yet. Not sure about rudder either. Neither can be balanced until fairings are done and I would assume paint. HS should be easy since the inboard counterweights remain accessible.
Turner Billingsley
RV-14A FLYING!!
Old 02-13-2017, 07:28 PM
Mudfly Mudfly is offline
I like your idea Turner. I can't think of any issues with your setup, but I would like to hear other opinions with possible disadvantages.
Using your method, it may also be easier to add extra weight if needed by simply using a heavier material (steel) for your "nutplate plate"
Like you, I have not done too much research yet as to balancing elevators and how to accomplish.
However, there was a thread here a while back that did touch on this.
http://www.vansairforce.com/communit...d.php?t=145624
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2019 VAF Donation Complete
Old 02-14-2017, 01:37 AM
Thanks Shawn! This is helpful in that I will go ahead and balance now while everything is attached, once I fit the elevator tips in place. I was thinking of something a bit simpler in terms of adding weight, like bonding tire weights to the structure somehow (inboard for easier access?). I will check with Vic Syracuse, my EAA tech counselor, on this and report back here. Just as in that thread, my left elevator is biased "forward" and right "aft" and when tied together close to neutral, but it makes sense to balance individually. At final assembly, after paint, should be easy to adjust.
Turner Billingsley
RV-14A FLYING!!
Old 07-19-2018, 08:12 PM
JoeRV14 JoeRV14 is offline
Default What did Vic say?
Hey Turner! Curious what Vic said to do here...Iím starting to get close to balancing mine.
Joe
