Old 08-05-2018, 12:25 PM
wawrzynskivp wawrzynskivp is offline
Default Cooling air loss?
I have the stainless steel unit from Spruce Part # 08-01311.
Looks like a constant useless leak of cooling air when valve is closed. Does anyone know a reason not to block the bypass side of the valve box?
Old 08-05-2018, 01:31 PM
Brantel's Avatar
Brantel Brantel is offline
I have been told that heat muffs donít like to be dead headed.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-05-2018, 04:23 PM
This is a pretty standard practice (bypassing the airflow) on experimental and certificated aircraft to keep the heat muff(s) from overheating and burning through.
Scott McDaniels
Hubbard, Oregon
Old 08-06-2018, 09:19 AM
Default Muffs need good airflow ;)
A call to Vetterman confirms the advice here. Their opinion is that folks that have stopped airflow through the heat muff see premature breakdown of the stainless components.
Better COA is to open or remove the heat muff and seal the heating duct during the hot months when cabin heating not anticipated.
