Old 08-28-2016, 05:02 PM
Brent 801's Avatar
Brent 801 Brent 801 is offline
Default Stainless heater bypass valve
Has anyone replaced the aluminum heater valves with stainless and if so who was the vender?
Built and flying since 2012 RV-8 81764
Building RV-14A 140229
Donation 12/18
Old 08-28-2016, 05:28 PM
MED MED is offline
I think Cleaveland has one.
Old 08-28-2016, 05:33 PM
Ron B. Ron B. is offline
If you look closely at what Van's provided with the RV-14 kits, you will see that the closure and mounting hinge is S.S. The box is alum. but in case of a fire the SCAT tubing will burn off anyway, so what if the box goes with it if the flapper keeps the hole plugged.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 08-29-2016, 05:21 PM
Brent 801's Avatar
Ron,
I looked closely at the heater valve today and you are absolutely correct. the flapper itself is SS. You just saved me a couple of hundred dollars. That will pay my VAF dues for quite a while! Should have known that the Van's engineers are smarter than me.
Brent
Donation 12/18
Old 08-29-2016, 05:42 PM
salto salto is offline
Don't forget Brent that there are different rivets called out for that flap also.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 08-29-2016, 08:50 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default Got a part #?
What is the part # for this al/ss heater box? Is it the same as used on the 7's? Updated or option? Admittedly I'm not current on the research for this but it's on my soon "to do / buy" list.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 08-30-2016, 07:03 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default link
http://www.robbinswings.com/
Robbins Wings Inc.
Rick Robbins
7087 W. 94th Ave
Broomfield, CO. 80021
The choice of many RV, Glastar and Rocket builders because of their light weight and compact design.
Mount the box on the firewall to direct and control heat to the cockpit or windshield.
Descriptions
Compact 2 1/4 H X 5 1/4 L X4 W
Lightweight less than 5 ounces
6061 T6 Aluminum construction
304 stainless door, control arm & hinge assembly
High temp neoprene seal at firewall
Alodine finish for corrosion resistance
Available with 1 or 2 inlet
Pricing
$65.00 (US)
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 08-30-2016, 10:09 PM
Robbins Wings Inc.
Rick Robbins
7087 W. 94th Ave
Descriptions
Pricing
$65.00 (US)
Hmmmmm..... looks just like the ones that come in the RV-14 kit (except for the alodine)
Scott McDaniels
Hubbard, Oregon
Old 08-31-2016, 04:09 AM
DanH's Avatar
DanH DanH is offline
Systems are only as good as their weakest link.
The box referenced above will require (as previously noted) stainless or monel rivets. A stainless flapper won't do you much good if it falls off the firewall after the rivets melt.
Personally I'd rather see a flapper with the cable control on the inside of the firewall. Same reason; the stainless flapper won't work unless held firmly closed, and a red hot Bowden cable in compression probably won't get 'er done. It would be iffy even if the hot cable was in tension.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-31-2016, 07:02 AM
Bob Martin's Avatar
Default This one--heater bypass valve
http://www.planeinnovations.com/prod...-valve-hbv-02/
With cabin side control lever for RV-7, RV-8 and RV-9.
The cabin side control unit is commonly used on RV7, RV8 and RV9 aircraft where the air is distributed in the cabin through a plenum.
All stainless steel construction offers a fireproof closure in case of an engine fire.
Designed with weight in mind, our stainless unit weighs 3.95 ounces and replaces the TG-10 aluminum box that weighs 3.28 ounces.
New flapper design offers better seal to keep out hot air when closed.
Born from necessity and designed with a passion for flight, the products offered by Plane Innovations LLC were thought out by builders looking for better solutions and thoroughly tested prior to release for sale.
The designs of these products have been directed at safety concerns, longevity and convenience.
Our products offer superior functionality for the experimental aircraft builder/owner.
I recently updated my firewall and installed two of these. Well built, all SS and actuator arm on the inside like my original.
FYI..2 inch hose and mounted with AN bolts (this was a RV-14 thread I jumped into with RV-6 experience)
Bob Martin
