Old 12-16-2014, 04:02 PM
crabandy crabandy is offline
Not sure how different the 7 is from the 8, but I was surprised to see how well it worked running the wires out the bottom of the stick. I used dsub pins in heat shrink as a disconnect point, doubled up the heatshrink and it fit nicely between the 2rod end bearings. I doubled it back onto the lower control stick, wrapped it with silicone tape and secured it to a "node" on the other wiring behind the spar.
Since my copilot stick was removable I did like previous posters and ran the wires out if the stick but under the stick boot
RV 7 300 hours and counting
12/17 donation
Old 12-16-2014, 04:42 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Originally Posted by Paul Tuttle View Post
I drilled the stick just under the grip and ran the wire down the front of the stick.
Can't see the wire. As stated in other posts, the further from the pivot point the better.
If this is done, it will interfere with the Anti-Splat Aero gust lock mechanism (probably not an issue for taildraggers, but for us nosegear guys...different story).
Just an FYI.
Old 12-16-2014, 05:11 PM
DanH's Avatar
DanH DanH is offline
The OP has an RV8 stick, which nothing like the stick from a side-by-side model. Can't run the wires out the bottom.
Weld on a reinforcement patch above the pivot and drill as desired.
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-16-2014, 05:16 PM
BillL BillL is offline
Perfect!!!
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 12-16-2014, 05:51 PM
glenn654 glenn654 is offline
Has there ever been an incident of a stick breaking anywhere?
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
Old 12-17-2014, 10:41 AM
Blain's Avatar
Blain Blain is offline
Would you Tig that, Dan?
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2019(my reminder)
Old 12-17-2014, 12:28 PM
DanH's Avatar
Did tig that, but O/A is fine too.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-11-2015, 09:59 PM
Blain's Avatar
Default Vans response
Questioned Vans and got a response. Too late for me, I had already made my decision. But as a conclusion to this thread I thought I would pass it on.
Copy of email;
Sorry for the delayed response, I finally got word back on this from the engineers. They will
allow a 1/4 inch hole (no larger, smaller is preferred) on the forward side of the stick just
above the cross tube. I have take pictures of what we have on our RV-8, this hole is 3 3/4 up
form the bottom of the stick. See attached picture.
Sterling
BTW, I put a 1/4" hole on the aft side about the same height as suggested. Will probably plate it per Dan H. diagram. Seems that there would be less tensle stress on the aft side but I'm no engineer......and they probably wouldn't endorse a bent stick either.
Blain
R-22 sold.
N82 Sierra Tango
Old 01-12-2015, 08:31 AM
maus92 maus92 is offline
The Infinity grip cable is fat, so something has to be done. I was thinking about welding some bar stock or possibly even a sleeve to "double" the area where the cabling exits the stick, but the patch seems to me to be the most elegant solution.
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 01-12-2015, 08:46 AM
Copy of email;
Sterling
Ok, this is what I have used over the years and seen no problems with. If you are concerned with a stress crack starting from the edges of this small hole. I offer an old trick that works to make this area of a tube much stronger without welding. Take two strips of .040 or .050, 4130 about 3 inches long. form them into a sleeve that will fit around half of the stick tube.
notch out for the through bushing weld, drill a hole to match the place you drilled the hole in the stick. Leave a little slack between the two along the edges wear they come together, maybe 1/8" or so. Make sure you round and be-burr everything, prime it all as you wish. Put your two fish plate you just made onto each side. Then take some .032-.021 safety wire and spool it around the stack-up with a good pull on the wire while you rap it around. You could cut a peace say 4 foot and put one end into a vice, then spool and rap to make a nice looking wind. This method has been used for thousands of years and there is no telling who came up with it so, if you like it as I have at times and you get concerned about a stress riser in this little hole, you may wish to give it a try. Hope this helps. R.E.A. III # 80888
