Old 08-11-2018, 01:27 AM
Aluminum Aluminum is offline
Originally Posted by Ron B. View Post
Rivets were definitely not set properly. Discovered my mistake. The first gun I tried, the smaller tip hole would not fit so I used the next size up. It must have been too large. I tried another gun this morning that had a hole that was tight , but the stem still slid thru. All rivets set properly now.
Ron
Ran into the same issue with the large CherryMax rivets and HF puller. I was able to finish setting the rivets using a squeezer--the steel mandrel makes a loud pop once it's driven in properly (that's the second pop that was missing when using puller) and ends up flush with the top of the rivet.
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
2019 dues worth every penny
Old 08-11-2018, 08:58 AM
Ron B. Ron B. is offline
What do you mean by a squeezer. As in a solid rivet squeezer?
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 08-11-2018, 09:40 AM
Affirmative.
Dan V
RV-14A in progress
Old 08-11-2018, 10:05 AM
mturnerb mturnerb is offline
Vans has a video describing how to lubricate the mandrel/stem on CherryMax rivets to address this issue (old rivets are the cause IIRC): https://www.youtube.com/watch?v=lb9miRllZDo
Turner Billingsley
RV-14A FLYING!!
Old 08-11-2018, 11:59 AM
There are numerous causes of the rivet not setting properly.
Another one is alignment. If the tool is tilted to the side slightly, it tends to add additional tension load on the river stem and can cause it to fracture prematurely.
Scott McDaniels
Hubbard, Oregon
Old 08-11-2018, 02:42 PM
My kit is a few months old, and the -5 rivets don't look any more aged than the -4 ones that set perfectly every time, so I doubt rivet age has anything to do with it. I am using an "unapproved" puller so Ron's explanation fits. There are only a few of these big CherryMax rivets in the entire kit, so touch-up with a squeezer is much more economical than getting a special puller, making a mess when drilling out, etc.
Thanks for the video pointer, I'll try the lubricant trick next time.
Dan V
RV-14A in progress
