Old 06-28-2014, 04:55 PM
kritsher kritsher is offline
Default gascolator o-ring size
I managed to destroy my gascolator o-ring as I was reassembling it. Does anyone know the o-ring size and/or van's part number? I can't find it on the van's website...
Ken
Old 06-28-2014, 06:05 PM
Mich48041 Mich48041 is offline
AirWard O-Ring
Vansaircraft O-Ring
Wicksaircraft O-Ring
The RV-12 uses the Usher GAS 5 Gascolator.
Joe Gores
Old 06-28-2014, 06:45 PM
Thank you Joe!
Ken
Old 07-25-2018, 01:57 AM
Yen Yen is offline
I can't find how to post a new subject, but I have a problem with the Vans gascolator O ring.
I had a leaking O ring and tried to get a replacement locally. That was no good so I got one in from Vans. That one leaks. The gascolator is a Vans G4
Has anyone else had O ring problems with this Usher manufactured gascolator? Does anyone know the actual sizing of the O ring?
I can't understand why the O ring should suddenly leak and a new one not work. There is nothing visible and a pressure test proves it is the O ring, not a leaking thread or gascolator body.
Old 07-30-2018, 04:41 PM
JAE JAE is offline
Default TECHNICAL DIRECTOR
The "O" ring used on the Gas 5 Gascolator is GAS-3-4-5 Gasket. This is listed in the Vans Accessories Catalog.
Old 07-31-2018, 03:03 PM
Are you sure the surface of the metal contacting the O ring is free of debris and damage? A gouge in the metal might cause a leak.
I remember somewhere in my past where we had a new O-ring in an air system that was leaking. We finally found a small defect on the ring with a jewler’s loop. Nobody believed it could be the issue, but another O-ring solved the problem.
The ring might be rolling when you put the bowl back on. Try a light coating of grease on it when you put it on.
