tomkk
Hi everyone. I'm just starting an RV-12 build. The empennage kit is mostly finished and waiting for my wing kit. I was just wondering how discrete, if that's the right word, the rest of the kits are. The empennage kit, or example, was almost totally complete and not dependent on any other kit (except for the tailcone fairings). Is that generally true? I was planning on doing the wing kit next and was going to order the fuselage kit timed to arrive sometime around when I expect to finish the wings. Then the finishing kit when I expect to finish the fuse then the avionics then the engine sequentially in that order. Does that make sense or would it be better to group the finishing kit with the fuselage or engine because of a more convenient order of build?
I've looked at quite a number of builder's kitlogs but, without being able to see actual kit instructions & contents, it's hard to tell whether they're being built sequentially by kit or whether there's a temporary pause in one kit to complete something in another because it's more convenient to do it that way. It looks there might be some advantage to getting the fuse & finishing kits together but not sure. I have seen a number of posts about delaying attaching the tailcone and rear window skins, I guess at least until after drilling the flaperon actuating arms, but not much other than that.
My only motivation for trying to sequence the kits is storage space for unused kits while working on earlier ones but I'll figure out something if that makes more sense.
