If anyone is working on the wings, can you please answer a question for me? It's been a while and I can't remember how this bracket (W-823-1) was attached (threaded hole, nutplate, nut). I need to take out the right bolt to attach a servo bracket, but if there is a nut on the other side, I don't want it falling into the outboard leading edge which is riveted on. I don't think there is a nut because it is not called out for in the plans. At this point, I want to be sure before I loosen the bolt.
Here is that little bracket. Also, I am assuming the roll servo and the pitch servo will mount like the 10. Garmin's instruction manual pictures look just like what we have. If you are ordering the kits, you don't need the bigger brackets, just this smaller support bracket.
