Barneybc12d
Looking aft at the last bulkhead (F-01412) in the tail.
I haven't run across this before, but I will trim this tab so it sits flat.
This is where the side skin overlaps the aft bottom skin. I did put a slight break in the side skin, but the gap is about .040. Is this normal or should I try to get a tighter joint? The joint between the side skin and the bottom skin is tight.
