tadpole rider
This is in a new -12 with first flight last Saturday. We did not fly too long as the CHT went into the yellow. We tried the climb to 10,000 but as we passed 1,500 the CHT went in to the red and it cooled down as we returned to the airport.
OAT low 60'sF.
Rotax 912 with the newer CHT probes that actually measure coolant temps.
Zerex Dex-Cool 50/50 coolant.
Cooling system has been purged of air and topped off.
The CHT sensors have been checked against boiling water and the give the correct resistance and the reading on the Skyview matches.
On the climb-out at 75 KIAS the temperature peaked at 270 when we aborted the climb. The oil temps were in the green.
The radiator was pulled and back flushed.
Any other suggestions? Van's had none.
N4212C
OAT low 60'sF.
N4212C
