Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 05-13-2019, 09:07 AM
painless painless is offline
Default FlightAware/Flightradar 24 tracking
Do FlightAware or Flightradar24 track aircraft with UAT installations? I can’t see my past flights in either site. Have GRT Safefly/Uavionix Echo UAT installed. I pass my FAA report.
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 05-13-2019, 10:07 AM
Default history
I don't know how far back your previous flights are but both of those apps will allow you to see some recent past data for free.
If you want a longer history, you will need to purchase one of their upgrade plans...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 05-13-2019, 11:10 AM
YellowJacket RV9 YellowJacket RV9 is offline
Yes, however the coverage is more spotty as not as many of the ground uplinks monitor UAT. Also, with FlightAware you need to create an account and change your settings to “Show Position Only flights”. Otherwise, they only show flights for which they have a field flight plan. A year ago almost none of my flights showed up. These days, at least portions of most of my flights are on there.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 05-13-2019, 12:48 PM
Jvon811's Avatar
Jvon811 Jvon811 is offline
I also wonder this and have a theory that it has something to do with the way I'm into the ATC system.
Again, just a theory... I would love to learn from someone who knows how "the system" works.
I too have the GRT SafeFly and Uavionix Echo and had Uavionix Tech Support walk me through the set up via telephone so I'm very certain its configured correctly. The only time I consistently show up on FlightAware is when I'm getting flight following on a long XC out of state or across the state. If I'm just flying locally (KFNT, Flint, MI) they give me a local squawk code and I don't show up on FlightAware. Might have something to do with it
-Justin
RV-4 N249P O-320, Dual P-Mags, Warnke Prop, GRT Sport EX
Old 05-13-2019, 01:39 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Try this first.
FWIW local "flight following" traffic data is not passed on to the FAA "national" system so that data is not available to anybody outside the local ATC facility.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2019 Dues Paid
www.PuertoRicoFlyer.com
Old 05-13-2019, 02:23 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Chris
Interestingly enough, I got curious about FlightAware, brought up the App, and typed in the tail number of my little jet (N958PD). I haven’t talked to anyone, nor filed a flight plan on it, yet quite a few of my test flights show up on their tracking. Not all of them, by any means, but some of them. I can’t figure out the differences between those that do, and those that don’t - almost all of the flying has been above 12,000’ so far.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-13-2019, 02:33 PM
Flying Canuck Flying Canuck is offline
Default Mode S works
I don't look at FlightAware very often, but I've found that all of my flights show up on flightradar24. I have a Mode S transponder and as soon as I turn it to ALT I show up, regardless of whether I squawk 1200 or a discrete code. This is the case in Canada and in the US. I don't have ADS-B. I also run a receiver for flightradar24 (cheap way to get the Business level membership) and I know it picks up aircraft with mode S.
Claude Pitre
RV-9A #91081, C-GCPT
Dynon SkyView HDX, IO-320 and WW 200RV C/S. Flying as of August 6, 2018
Old 05-13-2019, 06:28 PM
wnplt wnplt is offline
FlightAware and Flightradar24 do not track UAT. I have the same echouat. It rarely triggers FlightAware but never Flightradar24 unless given a squawk code.
Old 05-13-2019, 06:53 PM
larrynew's Avatar
larrynew larrynew is offline
I have the older Dynon SV-ADSB-470 which is UAT only. I always show up on Flightaware and have for several years. In all 48 lower states. VFR 1200 no flight following. Their free account keeps the history for 3 months. I use it to cross check (help me remember) where I flew for my logbook.
Larry New
RV-7A - Flying 800+ hrs
48 States in 7 Days!
RV-10 - On schedule to fly summer/fall 2020
VAF Paid - Annual Autodraft
FlightAware is tracking UAT, albeit with less coverage. They are now also selling UAT receivers for their ground station uplinks. https://discussions.flightaware.com/...-antenna/45405
Chris
Chris Johnson
