Old 11-06-2018, 07:49 AM
markelliott markelliott is offline
Default Do I want Steps? -14 taildragger
Need to make a decision.......help? Do I need / want steps on a -14 taildragger? I know it's my choice, but for those of you who fly the -14 Taildragger what do you prefer?
if its a 14A doesn't matter your opinion - sorry
Old 11-06-2018, 08:23 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
I bought and installed them but im not flying yet. I figured they will help passengers and if i dont want them they are easy to remove. However if I built without them then changed my mind they would be a pain to install after the fact.
Rob Lasater
Rv-14 still workin
Paid nov 2018
Old 11-06-2018, 08:42 AM
Mark33's Avatar
Mark33 Mark33 is offline
I'm going to be putting them on my -7 tail dragger. And like Rob, I'm going to make them removable. On the -7, I'll have to shorten them to probably about half the length they are now. Personally, don't need them "yet" to get in and out of the airplane, but I think they'll be a VERY nice option to have in place for my older passengers.
Old 11-06-2018, 08:45 AM
Mel's Avatar
Mel Mel is offline
It depends on your age and height. I am 75 and short. I need them. You will get older and your passengers may already be there.
I designed the steps for my -6. They go straight out behind the flaps, therefore they have no welds. Very simple. Give me your email and I'll send pics if interested.
A&P/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 11-06-2018, 08:46 AM
bkervaski's Avatar
At very least the steps would be an indicator to onlookers .. maybe avoid somebody stepping on a flap and causing some grief ..
Progress: Flying!
Old 11-06-2018, 08:48 AM
G5Driver G5Driver is offline
Mark,
I'm also building the -14 TD. I got a chance to sit in the demonstrator in OSH this year.
It had the steps and I noticed what a big step it would be without them especially for passengers.
I think it will be much easier to board with them and probably help save the flaps from damage trying to step over them.
In fact, they should have been included in the TD kit as they are with the -14A.
RV8, N658RL, 0-360, Hartzell CS, Dynon EFIS, (KCXP)
RV-14 QB #421
Old 11-06-2018, 08:52 AM
iamtheari iamtheari is online now
I had the opportunity test-sit in an RV-14 to see how I fit. No sense spending thousands of hours to build a plane that I hate to be in. It was a tail dragger that did not have steps, which made the decision for me: no steps on my RV-14. I figure that any passengers who need a step will be better off having me help them into the plane anyhow, and I can use one of those little folding plastic stools to aid with that process. But I'm 36 years old and 6'2". Check back in 50 years if I still think I don't need a step.
Old 11-06-2018, 09:26 AM
SabreFlyr SabreFlyr is offline
I've only just finished the tail feathers on my dragon-tail -14. However, I looked at the taildragger steps at Oshkosh and I'm convinced that my wife, if not I myself, will need the step. It's been a while so I don't remember for sure.
Ray Dosh
LJ45 driver
RV-14 QB #140212
Tail feathers finished
Tail cone started
2018 DUES PAID
Marion, IN MZZ
Old 11-06-2018, 10:59 AM
tjo tjo is offline
I'm building a 9, not a 14, but I did some research on this topic. Here's what I found:
1) Of the folks with tailwheels, most did not have them.
2) The ones that did have them wouldn't have it without.
3) Of the ones that did not have them there were some that wished they did.
4) There where some that went through the pain of installing them post build and thought it was definitely worth it.
5) Bob Axsom made his removeable, and speed testing showed less than 1mph difference with and without.
As a result, I am building with them. HTH,
Tim
Old 11-06-2018, 11:13 AM
Don E Don E is offline
Default I have them
Ever since i put my RV-14 on its gear, ive been VERY happy i bought and installed the steps. Im 6í3Ē and use them every time. Almost anyone who will fly with me (Iím in Phase I as of two weeks ago!) will need them. The step up onto a -14 is much higher and longer than onto any other Vanís tail dragger.
