Old 11-05-2018, 11:51 AM
Tmartin66 Tmartin66 is offline
Default PCU 5000X prop governor & IO-390
All,
I will be ordering my FWF kit soon. Has anyone used the PCU 5000X prop governor on the IO-390? Any problems mounting this governor? Any problems with the stock bracket and the prop control in the FWF kit.? Any information would be very helpful. Also will be using the Hartzel blended aluminum prop from Vans.
Thank you,
T. Martin
RV-14A under construction
N114TM reserved
Dues paid 2019
Old 11-05-2018, 01:39 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default works great...
The PCU 5000 can run from the back or front of the case and needs to be geared correctly for the choice... also, the direction of rotation can be CW or CCW. It can be changed from one to the other but you will have to send it back.
I suspect that the 14 has the routing worked out so you just need to order the right rotation and mount location.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
flying with more hours flying than building... 2,120 on the hobbs!
Race 771
margarita!
Old 05-13-2019, 04:41 PM
DakotaHawk's Avatar
DakotaHawk DakotaHawk is offline
Rather than starting a new thread, I'll just resurrect this one...
It's time to order the prop governor for my RV-14 build. I'm going to take advantage of the advertiser special that was listed on the Front Page of VAF a few days ago - 15% off the price of the PCU5000X!
I need some specs, and the guys at Aero Tech can't answer for me. I'm putting the standard IO-390 with the Hartzell 74" prop on my plane. So...
1) Gov drive ratio - I'm assuming 947:1 based on Lyc IO-390 wide deck fwd mount.
2) Control lever rotation - clockwise or counterclockwise???
3) Oil Pressure to Increase Pitch or Decrease Pitch???
4) Take off RPM ???
If you've got similar setup, what were the specs on your governor?
_______________________________
Scott "Grumpy" Stewart
RV-7 N957RV (First Flight on Dec 18, 2009)
RV-14 N144P (Empennage complete, wings almost complete, fuselage almost complete)
#866 on the Van's RV-7 hobbs
#6563 on Van's generic hobbs
Arlington, WA
Old 05-13-2019, 05:05 PM
M McGraw's Avatar
M McGraw M McGraw is offline
4) Take off RPM ???
Can the sales rep look up the specs from a previous customer?
I have the PCU5000X on my RV14 with an IO-390 and the Hartzell blended airfoil prop. I’m not home to look up the info but I will PM you my name and address for him to see which one I purchased. I will say it was very difficult to order because they sent a spec sheet that was impossible for me to understand and a few of them really did not understand it either. Also, I had to replace the pitch stop screw because the one that came on the unit did not work with the -14 cable system. If you purchase it I can send pictures of the linkage. If I had it to do over again I would just purchase the one Vans sells and it would fit straight away.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 275+
2019 Dues Paid
The Dues Paid note is a reminder for me
Old 05-13-2019, 05:12 PM
mturnerb mturnerb is offline
I ordered the Hartzell governor, Hartzell prop - easy way to go IMHO. Both fit the standard kit/engine well, no muss no fuss...
Turner Billingsley
RV-14A FLYING!!
Old 05-13-2019, 05:15 PM
Bavafa Bavafa is offline
I have the PCU5000X on my RV14 with an IO-390 and the Hartzell blended airfoil prop. Iím not home to look up the info but I will PM you my name and address for him to see which one I purchased. I will say it was very difficult to order because they sent a spec sheet that was impossible for me to understand and a few of them really did not understand it either. Also, I had to replace the pitch stop screw because the one that came on the unit did not work with the -14 cable system. If you purchase it I can send pictures of the linkage. If I had it to do over again I would just purchase the one Vans sells and it would fit straight away.
Marvin,
What is the lowest RPM your governor operates at the coarsest setting. I have the Hartzell governor and not very happy as it goes down to 1700 RPM when it is pulled all the way. Hartzell tech has confirmed that this is normal for this model governor.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 05-13-2019, 05:34 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
This is being corrected to prevent others mistakes
.895:1
Counter clockwise for the RV-14
Oil pressure to increase pitch
2700 takeoff rpm
At least that’s how mine will be spec’d
Rob Lasater
Rv-14 still workin
Paid nov 2018
Old 05-14-2019, 04:40 PM
Bill Boyd's Avatar
Anyone got the specs worked out for the IO-540 C4B5? I'd like to get in on this and it's time to move on it.
C2YR-1BFP/F8068D
url=https://imgur.com/je9ZKlN][/url]
And by the way, Brad - I'll take a couple of those 6-cylinder P-mags any day now, pal
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 05-14-2019, 05:10 PM
MED MED is offline
Originally Posted by Av8rRob View Post
Page 9 of the operators manual says .866:1
2700 takeoff rpm
At least thatís how mine will be specíd
I believe the 0.866:1 is for a rear mounted governor. I think the front governor is 0.895:1. At least that is my understanding from Lycoming and Hartzell for my composite prop using an S-1-79 governor.
MED
140236
N435MD
Old 05-14-2019, 06:05 PM
Default double check this...
2700 takeoff rpm
You might want to double check this to be sure... the drive ratio depends on where it is mounted on the case and the rotation of the arm and RPM change is routing and description dependent.
Mine is forward mounted with the control arm over the top of the cylinders... push for high rpm (cw from HRRPM to LRPM)
947:1
Pressure to increase
2700 rpm take off
Stephen
Race 771
margarita!
