Old 11-05-2018, 06:02 PM
Scott Hersha Scott Hersha is offline
I used the hinges on my first RV (RV6), camlocks on my second airplane (RV8), and hinges on my 3rd and latest RV8. If I build a fourth (unlikely) it will have hinges. I was careful with installation and the pins slide in relatively easy. There is no pillowing like there can be with the camlocks, it is much less expensive, and the final look is neater in my opinion, v.s. rows of camlocks. Itís a personal preference. I can get my cowling off in 30 seconds (after removing the screws at the nose area - like we all have to do), and installation is only slightly longer, but quicker than what I experienced with camlocks. Both systems worked quite well, but I prefer the cleaner look of the hinges. I also used hinges on my wingtips. If I take my time, it will take me 30 seconds to remove, or reinstall my wingtips.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
Old 01-13-2019, 08:49 AM
paulsmit paulsmit is offline
Hi guys try replacing the pins with 3mm stainless steel cable soldered on the ends and sharpened like a blunt pencil. So easy to use!
Old 01-13-2019, 04:25 PM
Tom023 Tom023 is offline
Since I’m just now on the cowling section I can see how this might be attractive for the upper cowling to firewall hinges. How do you lock the wire in place? The solid pins lock into a bracket.
RV14A #140083
AW certificate issued
2018 Donation+
Old 01-13-2019, 05:38 PM
You can also slightly ‘ream’ the cowl hinges with a modified hinge pin. I did this on my RV6 many years ago, and with my new RV8 and it ended up working very well. Pins went in without much resistance and I was able to install them without using a pair of pliers or some other tool. When I got it back from the paint shop, they were once again very difficult to slip in - including my wingtip hinge pins - so I once again ‘reamed’ them. The reamer is the same size hinge pin with the end flattened with a hammer on the anvil end of my bench vise. This flattened end is just slightly wider than the normal hinge pin diameter. Chuck it in your drill, lube it up with something (I used lubriplate) and spin it in to the hinge. The reamer takes off any burrs or paint and allows the pins to glide in more easily, especially on a curve. On my wingtips I did each hinge half separately with the wingtips off, but the cowl pins would be better done with the cowl in place due to curvature. I didn’t need to do this on the firewall mounted cowl hinges because the pins are already smaller than the hinge installed in that location and they go in fairly easily. Numerous others have done the same thing before me. Jon Thocker turned me on to this trick in hinge fitting many years ago, and it works. I can remove my cowl in less than 5 minutes and that includes removing 12 screws (3 on each side of the spinner, 3 on each side of the cowl exhaust on the bottom). Putting the cowl back on takes slightly longer because of fitting the cowl on the nose area and being carefull about baffle seal fit. The pins go in as easily as they come out.
Hinge pins can’t be beat for appearance (my opinion only) and I would be happy to race someone on cowl removal/install with someone that uses camlocks. I’m not saying the hinges are better or faster, I just think it would be an educational exercise that many of us might benefit from. I would also be interested to know the outcome. I’m not anti-camlock. I used skybolts on my second RV (RV8), and they are very well made, look OK, and if installed correctly, work very well. I prefer the low cost and easier use (again, my opinion) of hinges. If anyone is interested in a little competition, lets say we set up a contest, say..... Oshkosh (Airventure) 2019 on Sunday late afternoon at the beginning of the beer exchange. We should have 2 examples of each design, and someone should video the event. Since this would compare camlocks to hinges, the other fasteners used should be removed before the shotgun starts, and on the install, the contest should end when these same cowl devices are installed (before any nose area or cowl bottom screws/camlocks are installed). I’ll concede, camlocks on the bottom would be quicker than screws, and not anybody (that I’ve heard of anyway) lately has used hinges on the bottom. I haven’t seen any camlocks on the nose area behind the spinner, although I don’t see anything wrong with that. So.... who’s in?? Can we have a contest to kick off the beer exchange??
SH
Cincinnati, OH/KHAO
JAN2019
Old 01-13-2019, 06:53 PM
Cwood2000 Cwood2000 is offline
I considered using nut plates affixed to the piano hinge. I hav a similar system in my 4 which I did not build. But, since mine is a slow build I decided to use sky bolts cam locks.
Aka YellaDawg
RV4
RV14 in gestation
Old 01-13-2019, 07:25 PM
romaja romaja is offline
Default Bicycle chain wax lube for hinge pins
Wax chain lube works great and no oily residue or streaking.
Link:
https://www.amazon.com/White-Lightni...+bicycle+chain
_________________
Jim Roman
Retired Airline
Rans S20 Raven Sold Built in 2016
Vancouver, Washington
ATP, CFI, II, MEI
