Old 10-29-2018, 08:12 PM
MConner MConner is offline
Default Main wheel nuts
New owner, just installed new main wheel bearings.
Having trouble lining up the large aluminum nut with the cotter key hole in the axle. It seems to be too tight on one gear and too lose on the other.
Why are the holes in the aluminum wheel nut not slotted like a typical castle nut? As it is, I am forced to settle for bearing tension based on when the cotter key holes align between nut and axle. Am I missing something?
Bought not built
EAA 180
48X
Old 10-29-2018, 08:20 PM
Mel's Avatar
Mel Mel is offline
Are you sure you didn't swap nuts left for right?
A&P/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 10-29-2018, 09:18 PM
Sam Buchanan's Avatar
been here awhile
You can drill another set of holes in the nuts.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 10-30-2018, 05:50 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Grease seal aluminum insert rings.
These rings can vary in thickness as well as the bearing seat depth in the wheel halve. If the nuts were ever matched perfectly to the axle hole, you could have disturbeb it by mixing components in the bearing replacement. Thickness matters.
Larry DeCamp
RV-3B flying w/ carb / Pmags / Catto 2b / Steam
RV-4 fastback w/ Superior XP360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 10-30-2018, 06:23 AM
Exactly, it is not likely that 10 year old bearings and new bearings will match the same hole due to differing depth . In conventional castle nuts there is no limitation to an exact hole alignment as the “castle” allows proper tension. I guess I will either over size the holes in the nuts or slot them parallel to the axel to give me the ability to apply proper tension to the bearings.
Bought not built
EAA 180
48X
Old 10-30-2018, 08:23 AM
Mel,
I am sure but now I am aware that the starting position of the nut defines the hole that may or may not line up. There is a hole in each flat of the nut.
Is there any reason to have the hole as close tolerance since or is just a cotter key that is in shear to prevent unscrewing the nut?
Bought not built
EAA 180
48X
Old 10-30-2018, 08:27 AM
Default Mconner suggestion
Just align the hole in the nut with the axle hole. Either shim the gap ( nut to felt wiper ring ) or face the nut in a lathe or sanding disk until the next hole matches the axle while the bearing has the preload/clearance you want.
Larry DeCamp
Clinton, IN
