Old 10-28-2018, 10:55 AM
JokerF22 JokerF22 is offline
Default Elevator 09-07 Step 5 Match Drilling
Morning All-
On 09-07 step 5, I知 supposed to match drill #40 through the trim tab spar into the trim tab hinge. However, my E-01405 spar only has #30 holes. I致e looked forward in the plans and confirmed that I値l be installing 3-3.5s in those dimpled holes later on, so I知 confused. Am I missing something? Am I supposed to do my best and just drill #40 using the #30 holes as the reference?
Thanks.
Active Duty USAF
RV-14A Empennage in Work (N410KA reserved)
https://rv14joker.blogspot.com/
Old 10-28-2018, 11:13 AM
AlexC AlexC is offline
Default E-01405 spar
My E-01405 spar was drilled #40 per the plans, and I just double-checked that the rivets I used for that step are indeed AD3-4 (Pg 09-14, step 5). If your spar was drilled #30, you probably need to contact Van's.
_Alex
Alex C.
RV-14A: Empennage mostly finished; Wing kit underway (finished second fuel tank)
https://alex-rv14a.blogspot.com
Dues paid
Old 10-28-2018, 12:10 PM
_Alex
A rare mistake from Vans i suppose. I値l call them tomorrow. Thanks for checking.
Active Duty USAF
Old 10-28-2018, 01:40 PM
mturnerb mturnerb is offline
If so the easy fix might be to match-drill #30 and use size 4 rivets. But definitely check with Van's.
Turner Billingsley
RV-14A FLYING!!
