Old 10-15-2018, 01:59 PM
asw20c asw20c is offline
Default Have I Forgotten Anything?
I'm about 1 shop-session away from the step where I will begin riveting the bottom skins onto both wings. I've spent months ensuring I had the pitot system designed and built such that I could install it and connect the wiring harness and plumbing by feel, installed conduit and extra pull-strings to future-proof both wings and be able to add new wiring without much trouble in the future, shielded the wiring harnesses in the left wing to protect the magnetometer from EMF, installed the RG-400 cable in the right wing for the VOR/ILS antenna in the right wingtip, and installed the Van's supplied wiring harnesses for nav lights, landing lights, stall warning switch, aileron servo, roll servo, magnetometer and ADAHRS. I think I have everything covered but I thought I'd do a shout out and see if there is something any of you guys might have included in your wings that would be a good idea and should be installed now before it is too late after the bottom skins are already on. Thoughts?
Empennage Complete Except for Tips
Wings Underway
Old 10-15-2018, 02:50 PM
control control is offline
Prepare for Aileron trim?
And maybe even doing some trial or final assembly of parts of the roll servo.
But the big picture is that you are more prepared than most of us
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 10-15-2018, 06:17 PM
Don E Don E is offline
Default Wing tip light ground
Be sure the ground for your left strobe light is at the fuselage, not the wing rib where my stock harness had it.
Old 10-16-2018, 06:28 PM
greghughespdx greghughespdx is offline
Likely a good stage to have a tech counselor or similarly experienced builder drop by and take a good look at it with you, if you haven't already. If there's anything that's easy to "forget," that's probably somewhere on the list.
Van's Aircraft - Director, Community/Media
Van's web site | Instagram | Facebook
Opinions, information and comments posted by me are my own unless stated otherwise. They do not represent direction/opinions of my employer.
Building RV-8A since Sept 2014 (N88VX reserved)
Dual AFS 5600, Avidyne IFD 440, Whirlwind 74RV, Superior XPIO-360
VAF build thread - Flickr photo album - Project Facebook page
Flying spam can, helped build/fly a few RV-12s and some other RVs
Hillsboro, OR (EAA 105)
Old 10-16-2018, 06:44 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default SB 16-03-28
My RV14 kit is #140195. I did the upgrade install of the aileron inboard hinge bracket on the rear spar before I installed the bottom skins. SB 16-03-28 came out just before I got to that point.
I don't know if your wing kit already had that SB done, if not you should do it before the wings get sealed up with the bottom skins. I can imagine how difficult it would be afterwards > lots harder than now.
Jeff Warren
Simpsonville, SC (SC47 - 10nm NW Triple Tree, SC00)
1946 Bellanca Cruisair 14-13-2 (72 YRS OLD 8/15/18)
RV14A (N14ZT), Ser#140195
Start 10/11/14
Dues paid 12/2/18 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
!! I SURVIVED RIPON ARRIVAL - KOSH 7/21/2018 !!
Old 10-16-2018, 08:43 PM
kiljoy's Avatar
kiljoy kiljoy is offline
I'm at the point I can rivet on my bottom skins whenever I want to... they're deburred, drilled, dimpled, primed, blah blah etc etc... but I'm not (yet).
Why do it now? Sure I have everything prepped like you to do pitot, extra wires, AP servo, magnetometer, etc... but why do that to myself when I can just hold off on putting them on? It isn't going to hurt anyone.
20 clecos per wing and they sit there awaiting the rest of the prep work.
my $0.02
- Kilroy
Dues paid (2019)
RV-14 #140394
Empennage - done(ish)
Wings - done(ish)
Fuselage - Crating late Jan. 2019
YouTube Build Channel
Old 10-17-2018, 06:24 PM
C-GRVT C-GRVT is offline
The bottom wing is a preferred place for an outside temperature probe, if it is intended to have one.
