Old 10-26-2018, 03:25 PM
lr172 lr172 is offline
Originally Posted by Walt View Post
GTX45R is 2.9 lbs, I think most 10's can afford that. A big plus is improved output power and reception do to the antenna cable being kept as short as possible and away from the other com antennas. Easy access and good ventilation doesn't hurt either.
Walt,
How did you mount the transponder back there? I am now thinking this will work better for me.
N64LR
RV-10 in progress
Old 12-13-2018, 11:26 AM
TFeeney TFeeney is offline
Originally Posted by Jesse View Post
This is how I mounted everything in a recent -10. The transponder if to he right of the right rib in a hole in the sub-Panel so it slides out aft.
Any concern with plugs mounted on the bottom of the boxes? Wouldn't a gravity assist be your friend here? Or does it matter?
Not being critical just wondering if one direction is better than the other.
Anyone ever have a loose connection affecting instrumentation? Knees knocking against wires in flight or while entering/exiting? Kids in passenger seat with short legs kicking feet up into the connectors?
I realize the plugs are mechanically screwed into place, but thinking about any/all scenarios...
RV10
QB Wings done "for now"
Fuselage in process - working Cabin Top
