Old 08-26-2015, 07:03 AM
DanH's Avatar
DanH DanH is offline
Edit: This is a fundamental engine design issue. The temps caused coking that caused the guides to wear, so they improved the wear resistance of the guides, now they stick because the root cause remains. The root cause is the guide wall temperature is too high. Running LOP, cooler EGTs, and CHT's will certainly help, if not eliminate, the sticking. The challenge will be the break-in conditions. Cool ambients and leaning will help to the point that CHT and cooling is not compromised.
Group...does field experience suggest angle valve engines exhibit less valve sticking?
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-26-2015, 08:46 AM
aerhed aerhed is offline
Dan, after working on a few hundred lycs and contis, I'm not sur if I remember sticking on ANY angle valves of either brand.
Actual repeat offender.
Old 08-26-2015, 09:26 AM
Plummit's Avatar
Plummit Plummit is offline
Wow this has been some really valuable information, and something I want to look in to regarding my engine. My understanding is that my engine came from Vans, then was sent to BPE for them to work their magic. Records indicate that they re-worked the engine and installed 9:1 pistons, with a HP boost to somewhere around 285.
Currently the engine has just over 200 hobbs hours, and we notice an occasional miss and roughness. The engine also seems to run smoother when hot.
~Marc
N814RV
2019 Donation Made
Old 08-26-2015, 09:50 AM
Mike S Mike S is online now
Originally Posted by Plummit View Post
I never run LOP. Typically I try for 50 ROP,
Old 08-26-2015, 10:13 AM
DanH's Avatar
Typically I try for 50 ROP, but have had a couple of overheat issues if I try climbing out on a hot day and don't do a good job of maintaining the airspeed at 130 kts.
I don't believe I'da toll 'em that.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-26-2015, 11:00 AM
BillL BillL is offline
Well - this certainly puts the angle valve in a more favorable light.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
Old 08-29-2015, 07:30 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
FWIW I did verify today that I have the newer valve guides with the "circle C" stamped on the head.
Bill Peyton
RV-10 - 950 hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 08-29-2015, 09:07 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
I can speak to one angle valve that stuck a valve.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit, building
Old 08-30-2015, 07:09 AM
DanH's Avatar
Of course, the next question would be "What vintage angle valve?"....old or new valve guide material?
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-30-2015, 08:22 AM
Dan,
In my case the newer valve guides didn't really make much of a difference. I have 400+ hours on the engine and still had a slight build up. In my case, I attribute this to the excessive oil consumption during break-in and for the first 50 hours or so. In addition, my number 5 cylinder would routinely get up to 400 on climb out. I now have redesigned the rear baffle plate to allow for better airflow and no longer have the issue to the same extent. Cylinder 5 was also the tightest guide clearance. In all cases, my front two cylinders run 10-15 deg. cooler than the rest. When I passed the reamer through the front two cylinders they were clear and had full clearance.
I did a climb test yesterday to verify one more time, that my issue was indeed a sticking valve. I kept the CHT's just under 390 all the way up to 7K feet at full power with no issues. I normally would not climb at full power, or best angle.
Bill Peyton
RV-10 - 950 hrs
WA0SYV
