Old 08-22-2015, 08:01 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Default The Sticking Valve Syndrome
I thought I would post this in the RV10 list since it applies to the IO540 D4A5 typically installed in the RV10, although feel free to move it.
About a week ago I noticed a slight miss/stumble during climb out. This occurred twice, but not on every climb out. It would only occur for a split second during the climb out, but did not occur during the cruise portion of the flight. Along with this symptom, during normal cruise I noticed a slight vibration that felt similar to a prop just slightly out of balance. You could see it in the glare shield. I downloaded the EFIS data from both occurrences and examined it looking for signs of something amiss. I knew the exact time of the anomaly, but it did not show in the data either because the sample rate was to coarse (1Hz) or it was not enough of an event to show up in the EGT, CHT, FF, FP etc.
After reading another post of a catastrophic valve sticking in an RV10, and then thinking back to another aircraft I owned with a Lycoming 360 having experienced a severe valve sticking. The more I thought about it the more I became was convinced that this too was sticking valve. Lycoming has a service bulletin addressing the inspection of the exhaust valve guides at 400 hour intervals, SB333C. I decided to perform the Lycoming Service Instruction No. 1425A which provides a suggested procedure to perform the action. Mike Bullock has a great write up with photos in this post http://www.vansairforce.com/communit...d.php?t=128673 . I had all the tools including the ream from the last time I performed this task over 10 years ago on the 360.
I was correct in my assessment. Cylinders 3, 4, 5, and 6 all showed evidence of a very slight "interference" fit" and would not pass the Lycoming wobble test. The .4995" ream required a little coaxing to get started in the guides, cylinder 5 was the tightest. I completed the operation on all six exhaust guides in about 9 hours and flew it the next day.
With the 360, I religiously add TCP, a lead scavenger, to the fuel every time I fuel up. I put an additional 1400 more hours on the 360 without any issues, then replaced the engine at 2100 hrs with a Lycoming OH and have flown another 1200 hours without issue on the new engine. I'm going to start using the TCP with the 540.
After 2 hours over 4 flights I feel confident the issue was indeed the beginnings of the sticking valve syndrome. I will be flying a long trip on Monday and hope to report a continued clean bill of health.
Here are the stats on my engine and operation:
- Factory new D4A5
- 411 hours since installation
- Magneto ignition
- 90% of time accumulated is cross country
- All X/C flights are run LOP
- Phillips XC 20W-50
- Camguard additive
- CHT's never allowed to exceed 400 deg.,normal ops I see 310-360
One thing to add to this is that during the break in period I had a high amount of oil consumption. This continued through around 50 hours before it stabilized at a Qt. every 15 hours.
Bill Peyton
RV-10 - 890
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 08-22-2015, 02:10 PM
jc11378 jc11378 is offline
Bill
Great write up more people need to do the wobble test at 400 hours, I have seen alot of planes have this issue over the years and to have 2 write ups in one week on VAF it tells me there are more to be found if people would look.
It will extend the life of the motor, and a good possibility to preventing a off field landing or worse a fatal accident.
Preventive maintenance is so extremely important.
Matter of fact I will do a talk at my next EAA Chapter meeting about this, for our plane owners.
John Cumins A & P for way to long
N864JF Reserved
Emp complete , slow build Wings Fuel Tanks Finished, ailerons, and bottom wing skins ready to rivet on. Working on Flaps
My Build log http://websites.expercraft.com/jcrv10
Home Base VCB Nut Tree
Eaa 1230 VP
VAF 2015 Dues Gladly Paid
Old 08-24-2015, 07:44 AM
Ollie Ollie is offline
Default Marvel mystery oil
My O-360 has never stumbled again since using recomendid amount of Marvel Mystery oil in the gas .
Ollie, 6A 180/CS -- Rans S7S
Loves Ldg. Airpark, Central FL.
Old 08-24-2015, 08:01 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Bill, were you removing metal or lead deposits with the reamer?
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 427.8 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 08-24-2015, 08:11 AM
I only saw black oil deposits on the ream....
Bill Peyton
RV-10 - 890
WA0SYV
Old 08-24-2015, 08:41 AM
aerhed aerhed is offline
That sounds right Bill. You coked it on break-in, I'd bet. If your spark plugs have good color now you probably will be good for a long time.
Actual repeat offender.
Old 08-24-2015, 10:53 AM
woxofswa woxofswa is offline
I remember Alan Barrett telling me about something that they do in all their engine projects that results in them having far fewer incidences of this problem than stock setups. As I recall, it can only be done on experimental, but I could be mistaken.
I just don't remember the details of what it was that they do. Anybody know the details?
Myron Nelson
Mesa, AZ
N24EV
RV-10 BPE, Dynon, Airflow systems A/C
First flight May 10, 2014
Old 08-24-2015, 07:26 PM
Ivan Kristensen's Avatar
Ivan Kristensen Ivan Kristensen is offline
Default Sticking valves.
Bill,
Check and see if you if your cylinders are marked with the number 3 with a circle around it. You can find this mark on the top of each cylinder on the bottom left hand corner next to the valve cover near the drain tube.
If a circle with the number 3 is stamped in this location then the SB referred to above does not apply. Now if you do have this symbol and still have a valve sticking problem then obviously something else is going on.
I now have 685 hours on my engine and it continues to run great. I run mine exactly the same way you do yours with mostly long cross country flights and always LOP. The only difference is that I use Aeroshell W100 Plus with no other additives.
Ivan Kristensen
Guelph, ON. Canada
RV-10 (C-GMDV) 1150hrs.
Dual GRT 8.4" EFIS, TT A/P, Avidyne IFD440, Dual EI's
Link to my build site:
https://ivankristensen.smugmug.com/B...ENTAL-aircraft
Old 08-24-2015, 08:12 PM
Ivan,
Do you know what the significance of the "3" is?
Bill Peyton
RV-10 - 890
WA0SYV
Old 08-24-2015, 08:20 PM
Default Valve guide
Yes apparently the valve guide is of an improved material and the clearance was increased.
Ivan Kristensen
Guelph, ON. Canada
