Old 10-27-2018, 03:20 PM
Freightdawg's Avatar
Freightdawg Freightdawg is offline
Default Not Riveted In This Section
On page 41-9, the farthest aft hole on each side of the forward fuse top skin is labeled NOT RIVETED IN THIS SECTION. For the life of me, I can't find where they ARE riveted. The same is true for the holes that were left unriveted in Section 29 (shudder) that were later used for fitting the doors (page 45-03). Where/when do they get riveted?
Thanks for curing my madness.
Jeff
Jeff Rich
RV-10 Kind of all over the place in the plans.
N313KC reserved
(12/17/18) We are IN the hangar now!!! (KJVY)
Old 10-27-2018, 03:36 PM
rocketman1988 rocketman1988 is offline
Default Good Question
I was never able to find where they were supposed to be riveted...so I did it after the cabin top was on...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues Paid 2018,...Thanks DR+
Old 10-27-2018, 03:49 PM
lr172 lr172 is offline
Jeff
That is one of the holes left for a door fastening cleco. They probably assume you'll figure out to put rivets in them after you are done with the doors.
N64LR
RV-10 in progress
Old 10-30-2018, 05:27 PM
Bob, thanks for the sanity check.
Larry, I think they assume too much. We were about to start the fairing at the base of the windscreen and realized it was going to cover an open hole.
Jeff Rich
N313KC reserved
Old 10-30-2018, 06:18 PM
I was the opposite. It was a QB fuse and couldnít understand why they were left out, so i put them in. Got my finishing kit and rwlized the error anc had to drill tgem out
N64LR
RV-10 in progress
