Old 10-20-2018, 11:44 AM
ShortSnorter ShortSnorter is offline
Default Minimum Aileron Clearance
I have two questions, both related to the aileron rigging:
1. What is the minimum clearance required between the aileron and the hinge brackets as seen below (The other side has 1/8")?
2. Stupid question, but just want to confirm: Is the entire hardware assembly (bolt, washer(s), bushing, nut) supposed to rotate as one with the aileron? In other words, with everything tightened down, the two washers are sandwiching the bearing which is moving about the race.
Thanks!
Ryan
RV-14 In-Progress
Build Site
Old 10-20-2018, 12:33 PM
lr172 lr172 is offline
1: not entirely sure of design spec, but my 6 has 1/32-1/16 (haven't measured it) in one place, I believe, with no rubbing or binding issues. The mounting is pretty ridged. Both of the 063 brackets (being riveted together, they are effectively 1/8" pieces for bending purposes) on both sides would have to bend 1/32 before contact and I don't believe there is a lot of side load on the ailerons. The bearing would fall out of the race before it moved that much in side to side motion. I just replaced one of those bearings that wore out and all of the movement seemed to radial and not axial.
2: yes
N64LR
RV-10 in progress
Old 10-20-2018, 01:53 PM
sjhurlbut sjhurlbut is offline
Default Clearance
Clearance should be fine if it doesn’t flex.
Bolt, washers, spacer will not rotate. Bearing will.
"Aerodynamics is for people who can't build engines"
Enzo Ferrari
Steve H
Cold Lake, Alberta
RV7A #70015 - C-FZQX - built - sold
RV7A #71629 - C-FSIS - built - sold across Atlantic
RV7 #70215 - C-GOJU - flying - sold
RV7 #70703 - C-GMIY - flying - sold
RV6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
RV10 #41779 - built emp - sold
RV8 #82842 - C-FSBG - Fastback with big hp IO-360-A1B6 10:1
Old 10-21-2018, 07:00 AM
Thanks for the clarification guys!
Ryan
RV-14 In-Progress
Build Site
