  #351
Old 05-13-2010, 09:40 AM
N8RV's Avatar
N8RV N8RV is offline
Default Wow ...
Some of you guys have truly AMAZING builds going! As was already said of Matt's plane, DON'T PARK ANYWHERE NEAR MY PLANE.
Seriously, some of you are setting the bar so high that even an above-average project looks like doo-doo. Congratulations to you all. I'm looking forward to seeing them all in person (just don't park next to me, OK?)
Carry on.
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 05-14-2010, 06:19 AM
N208ET N208ET is offline
Default N208ET
Is airworthy!!!!!!!!!!!!
Randy
8A
Old 05-20-2010, 09:59 PM
DanH's Avatar
DanH DanH is offline
Speaking of fittings....sometimes they just don't sell what you want, so you spend a pleasant evening with the machines.
Edit: Installed this AM....fitting connects a relocated brake reservoir with the master cylinders. Aluminum line runs parallel to the right brake line behind the panel, SS/teflon hose down to the cylinders.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-29-2010, 03:58 PM
bobby bobby is offline
Default Finally out of the jig
it's great to have it free of the lumbar.
Bob Anderson, VAF #2337
RV-8 Flying!!!
Santa Fe, NM
Old 06-07-2010, 08:40 PM
RV8R999 RV8R999 is offline
Default Rudder Painted
Getting closer every day!
http://i47.tinypic.com/2hmn8fb.jpg
Still a bit of touch up to do with a lil bleed through in a couple of places and for some reason I missed a couple of squares at the trailing edge..easy fix.
Last edited by DeltaRomeo : 06-08-2010 at 09:06 PM. Reason: Changed large image to link to large image....
Old 06-07-2010, 08:45 PM
Default Nice Fittings!
Dan - nice work. Great location for the reservoir for ease in servicing. What machine do you have to make such nice work?
Old 06-08-2010, 04:37 AM
DanH's Avatar
Originally Posted by RV8R999 View Post
Dan - What machine do you have to make such nice work?
An old Smithy, which is a lot like an old shotgun.....can't brag on it, but it brings home most of the food.
(hey, gentle reminder; don't neglect to crop/resize your photos before uploading)
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-08-2010, 05:09 PM
im using tinypic what else do I need to do?
Old 06-08-2010, 05:13 PM
BrianNC BrianNC is offline
Use REAL tinypic.
Old 06-08-2010, 05:27 PM
DanH's Avatar
The current photo is 1600 x 1200 pixels, which extends the right margin of the whole page and makes everybody pan back and forth to read the text.
Two choices......
Resize before you upload to a photo share. Almost any photo program will resize photos, so chances are you have the tool. 600 wide x any height works real well in this forum.
Resize during the upload to a photo share. Tinypic has that option; the "resize" block is just above the "upload" button. Select "Message Board 640x480" from the drop down menu, then click hit upload.
Please excuse the reminder and tutorial; I'm an AH and it's a pet peeve
Dan Horton
RV-8 SS
Barrett IO-390
