Old 12-26-2017, 12:33 PM
Len Len is offline
Default Flap Motor Failure
Flap motor quit right after conditional ... found thread in archives about cleaning motor of excess grease. Did this and it ran on bench again. Put in plane to test and it only runs one way using flap switch ??? Reverse wires and like on bench and it will go the other way. Thoughts?
Also I read where people have bought just the flap motor from the manufacturer? Mine was manufactured in 1999 according to data on motor.
Len Leggette
Greensboro, NC
Old 12-26-2017, 12:49 PM
Ironflight's Avatar
VAF Moderator / Line Boy
You've proven that the motor will run in either direction - so you most likely have a wiring issue. Check for a loose connection in the part of the circuit that drives the motor in the direction that isn't working.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-26-2017, 01:09 PM
Default What Paul says....
Or, the switch may have gone south on you.
If the flaps are all the way up or down, and the switch (or control box etc) fails in the other direction, it would appear that the motor has failed.
Old 12-26-2017, 01:24 PM
tfriendshuh tfriendshuh is offline
I had to replace the switch at the same time I cleaned the motor...
tim CP ASEL & S
RV-8A N6677F IO360 CS IFR
600 hours and counting
Dues paid!
Old 12-26-2017, 04:15 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Are you using a flap positioning system?
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 12-27-2017, 06:14 PM
F1R F1R is offline
Default What the others have said plus check relays.
Also could be a failed relay if your flap switch is on the stick and uses relays to feed the heavy current.
