Old 04-01-2019, 12:18 PM
Cwood2000 Cwood2000 is offline
Default Gasolator
Maybe I missed it in the plans, but I don't recall a gasolator installation. Is anyone installing one, where are you locating it?
Aka YellaDawg
RV14 First Flight 10.15.2019
RV14A under construction
2020 Dues Paid
Old 04-01-2019, 12:23 PM
rvbuilder2002's Avatar
The RV-14 was specifically designed to use fuel injected engines.
Fuel injected engines don't typically (in RV's at least) have a gascolator in the fuel system (except for meeting the requirement imposed in Canada).
The fuel system that is part of the kit does have a fine mesh inline fuel filter.
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 10-26-2019, 09:32 AM
Tom Sampson Tom Sampson is offline
Default Gascolator
Hi Scott ...
Just beginning to work on the fuel system in my recently acquired 9a project. The kit came with an Airflow Performance pump and filter ... so 2 questions ...
1. do I need a gascolator?
2. when I built my 2 previous RVs (9a and a 7) I used fuel-lube / easyturn for sealant on all of my fuel fittings. But that was over 10 years ago ...
In your opinion, is this still the common practice, or is Locktite 565 a better choice?
Thanks Scott!
Best, Tom
Tom and Martha Sampson
Portland, Oregon
Live Well ... Help Others
Rebuilt and Sold - Minimax Ultralight
Partial Restored and Sold - Aeronca Champ
Built and Sold RV9a
Built and Sold RV7
Consulted, Finished, 40hr Test, and Sold RV9a
Repeat Repeat Repeat Offender: 9a QB in Process
thomas.eh.sampson@frontier.com
2019 Contributions Made
Old 10-27-2019, 11:31 AM
Originally Posted by Tom Sampson View Post
Hi Scott ...
Thanks Scott!
Best, Tom
Are you using an engine that would be compatible with the Airflow Perf. pump (a fuel injected engine)?
If so, then the post I made earlier in this thread would apply (no gascolator would be used).
A lot of people have had success using fuel lube to seal pipe threads, but it is technically not a sealant and not what I would recommend.
There are specific recommendations in Section 5 of the construction manual. Loctite 565 (567 as well) is one of them and is a good choice.
A major benefit it has over fuel lube is the PTFE in the sealant. It helps prevent galling in situations where an aluminum fitting is threaded into an aluminum housing which is very beneficial if you ever have to remove/replace the fitting for some reason.
Scott McDaniels
Hubbard, Oregon
Old 10-27-2019, 07:42 PM
Default Gascolator
Thanks so much Scott ...
Exactly what I was looking for.
Best, Tom
Portland, Oregon
Built and Sold RV9a
Built and Sold RV7
