Old 10-24-2019, 09:42 AM
caapt caapt is offline
Angry Help. Canít get full travel on rudder
I canít get full travel when applying left rudder. The tabs for the brake pistons on the rudder pedals are hitting the tube for the other pedal. Vans was NO help. Ever hear a shoulder shrug over the phone?
14A Wing Complete!
Tail Complete
Fuse Complete
Engine installed
Wing Mounted
Inspected and certified 1-31-20
First Flight 3-25-20
Old 10-24-2019, 10:11 AM
Bgill Bgill is offline
Default Making sure
Are you sure that the correct tube is in front. The spacing from tube to tab is different. The forward tube has a longer spacing than does the rear. Someone posted a while back some issues and their tubes were reversed.
If thats not the case, pm me a photo or send me your e-mail and see if we can figure it out. I can then e-mail a photo of mine.
Byron
RV-10 40253 N253RV Flying
RV-14 140466 In build - Finishing kit
Douglas, GA. 2019 Dues paid
Old 10-24-2019, 10:45 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Are your pedals in the forward most position? If so your problem is that the links to the rudder pedals aren’t long enough. Their is a thread about this but long story short, you can buy two pieces of thin steel from Vans and fabricate 4 new ones longer. Having longer pieces allows the pedals to be in a more vertical orientation preventing one tube from hitting another.
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2019
Old 10-24-2019, 04:18 PM
mturnerb mturnerb is offline
This is probably the number one issue with -14 rudder travel. Check out E's outstanding post on his blog: https://rv-14a.blogspot.com/2017/10/...e-systems.html
My rudders are middle position and I used the full length of the links to get good travel.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
Old 10-24-2019, 04:24 PM
I also thought of this - can't think of another reason there would be interference. Also suggest carefully checking install of brake cylinders against KAI. Easy to make a minor error that could cause interference issues.
Turner Billingsley
Old 10-27-2019, 07:46 AM
Default Problem Solved
Moved the pedals out of the most forward position. Both the center and aft position give full range movement for the pedals. Thank God I didn't
have to get creative with the fix.
14A Wing Complete!
Tail Complete
Fuse Complete
Engine installed
Wing Mounted
Old 10-28-2019, 09:20 AM
Lizard Lips Lizard Lips is offline
I had the same problem and, thanks to this forum, I found I had installed the tubes backwards. Reversing them (not an easy job) solved the problem. Gotta read the drawings very carefully or problems are almost guaranteed.
Joe
Longview, TX
RV 14A wings complete
fuselage complete
engine installed
working on cowling
next step … move everything from shop to airport and install wings
gettin' close
Arion Lightning LS-1 flying regularly
2019 dues paid
