Need advice re my 12 with Dynon 180 & 100. When cruising, the digital voltage reads 13.5, and the vertical bar shows voltage at low end of green.
At low power (taxi) the digital voltage reads 11.5, and the vertical bar indicator shows at bottom of scale--red zone???
Does digital reading reflect battery voltage, and vertical bar reflect generator output, or ?? I don't know if regulator-rectifier is working or not??
