Internal vs. External Star Lock Washers
David Paule
Which should I use where?
While my immediate application is for steel screws into threaded aluminum, I'd appreciate learning about the reasons for one or the other generally.
Thanks!
RV-3B, still, yes, even now, skinning the fuselage
My WAG is that it has to do with size of the bolt/screw head - needs to cover teeth of washer. Just a guess though
My understanding agrees with Mturerb. Fasteners with a larger head, in proportion to the thread diameter, do best with external tooth washers. Those with smaller headed fasteners (such as filister heads) do better with internal tooth washers. The electronics industry often uses washers with teeth on both internal and external of the same washer. :eek:
