dbaflyer
After spending several hours trying to fit the vans lower fairing (F-994A and rubber strip) I decided it was fruitless trying to get it to fit properly. I had some gaps here and there and the rubber was so cut up it wasn't going to last very long. I also have some rework to do on the upper forward part of the fairing. I tried to rework that portion with some heat but it basically just warped it more and it is is kind of rippled. So I plan to jump into some fiberglass work. I do have some questions (very newbie):
I plan to trim away about 1-2 inches from the forward most portion of the upper fairing. How much overlap should I use when laying the new glass down?
How many layers of FIBERGLASS CLOTH 7781-50 from Spruce (8.95 oz) will it take to get the thickness of the current fairing? Should all the layers be made at one time?
Should I use full length strips, running from HS rear to HS front, when making the lower fairing? Or will it matter to use shorter ones which would probably be easier.
Should I use peel ply on everything I glass? Does it matter which direction the peel ply runs?
Should I use any release agent other than the packing tape I have applied?
Will cabosil be needed to thicken the resin or will the wetted fiberglass strips just "stick".
Here is a picture showing my plastic mold for the lower fairing. I do need to trim the lower part to be shorter and more even.
