After several months of slow, on and off progress (interruptions due to work, and other commitments) I have finished the sliding canopy on my -7A. I am very happy with how it turned out... actually professional looking. The pros and cons of using Sika Flex adhesive to attach the canopy has been pretty thoroughly debated so this post is intended simply to document my experience. I'm not trying to change anyone's mind.
For anyone who wants to use the Sika Products for this, hopefully my experience will make that part of the RV homebuilding journey a little bit less uncertain. This method was not hard (although I have no basis for comaprison vis a vis Van's suggested method). I drilled exactly 1 hole in the plexi (for the latch handle) and I didn't need any shims between the frame and the bubble (the glue compensates for any irregularities) and I have no cracks (but that's not a surprise as I didn't drill any holes). I think the main benefits of going this route are that there is less risk of cracking and it looks really nice. I plan to use Sika Flex adhesive for the windscreen as well even substituting the glue for the fiberglass molding around the base of the windscreen. That will make it relatively easy to replace the windscreen if it is ever cracked by some traumatic event (bird strike etc). The adhesive sets into a rubber-like consistency which is easily cut with a razor blade. After working with this stuff and trying to pull apart some samples I made I am confident in the strength of the glued joints (how's that for scientific?)
I had posted an intermediate progress report a while back with a link to a PICASA web album. Now that the skirts are installed and the thing is done, here's that same link again but now there is aditional photos and text.
http://picasaweb.google.com/rvtach/GluingMySliderCanopy
Jim McChesney
RV-7A starting FWF and electrical
Jim McChesney
