  #131
Old 03-27-2018, 01:18 PM
I opted to substitute a solid AN4 rivet for one of the LP4-3 on the HS-01231C Hinge Gusset mainly to keep up appearances.
You will need to temporarily remove the AN3 bolt on the Hinge Bracket Assembly to allow access for rivet squeezer.
Hinckley, Ohio
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 409
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 03-27-2018, 01:59 PM
pstraub's Avatar
pstraub pstraub is offline
Wow, already painted and matching rivets....nice Jim
Paul Straub, First Flight May 5, 2017
N917PB, SN 120971
120 hours and counting.....
Old 04-04-2018, 11:59 AM
johnhuebbe johnhuebbe is offline
I placed my order on the Vans site back on February 23, but still haven't received the parts. Is this typical?
Old 04-04-2018, 12:22 PM
DaleB's Avatar
DaleB DaleB is offline
I'd definitely call and ask about it. They shipped mine in less than a week.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 04-04-2018, 01:23 PM
Default Installing the Stabilator is a Royal Pain...
I finished SB 18-02-02 and yesterday finally had warm enough temps to allow reinstalling the Stabilator. I followed KAI Page 11-03 instructions for attaching the Stabilator Assembly to the Tail Cone Assembly which details gluing the AN960-416 (OR -416L) washers to the Stabilator Assembly Hinge Brackets. I chose new -416 thin washers and scuffed the surfaces before gluing with super glue.
I had a problem trying to guide the Hinge Brackets over the Pivot Bearings. In my case the bearing inner race would dislodge one of the four washers with each try. The top and bottom U-shaped stiffener plates added to the new hinge brackets severely restrict access for hand placing these washers during reassembly.
My solution was to substitute a larger washer with more surface area for gluing. McMaster-Carr has a 316 Stainless Steel washer 1”OD x 0.281 ID x 0.040 thick. Hole diameter for AN960-416 is 0.265 so this larger washer has hole oversize by 0.016 so you need to center the washer over the hole in the Hinge Bracket when gluing. The new washer clamps the bearing inner race when tightening the assembly so no problem there. You will have to file two flats on the Stainless Steel washers for the outboard Hinge Brackets to clear the T-nut rivets.
A lot of folks have said that installing the Stabilator is a royal pain. With four of these large Stainless Steel washers glued to the Hinge Brackets the Stabilator slide onto the Pivot Bearings like a charm.
My 12 is licensed ELSA so substituting these washers is at my discretion. SLSA will need to follow the SB to the letter.
Disregard old Hinge Bracket and short AN bolt in photo…
Hinckley, Ohio
EAA #499867
Old 04-04-2018, 01:25 PM
As an update, I contacted Van's. Many orders have been backordered (including mine). I was told that more would be shipping in a week, so hopefully my order is included in that shipment.
Old 04-04-2018, 06:07 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Thumbs up Good report
Great tip Jim, Thanks
Tony
RV-12 #202 -- Flying
Old 04-04-2018, 10:21 PM
DHeal DHeal is offline
I guess I might be a bit concerned about potential galvanic reaction with the mix of aluminum /steel / stainless but I can't say for sure. I used a piece of thin but stiff plastic sheet bent over each bearing (with a dab of grease) to guide the brackets into place without excessively molesting the glued washers -- then pulled out the plastic sheet and inserted the bolts.
ps -- Another tip: Before you remove the tail cone, temporarily position the four skin gussets in place on the stab and mark how much of the tail cone openings you will need to trim. Doing this in advance will save you from having to reinstall / mark / trim / reinstall the tail cone a second time.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 725+ hours (as of Jan 2019)!
VAF donation through June 2019.
Old 04-05-2018, 04:24 PM
David
Your point is well taken. I hadn’t considered the possibility of dissimilar metals, thinking Stainless Steel would be impervious to corrosion.
It’s been a very long time since I took a metallurgy class in college. I found a Galvanic Corrosion Chart listing 316 SS and a 2017 tempered aluminum alloy (Van’s uses 2024 alclad aluminum). The interaction doesn’t appear too bad if the 316 SS is in active state. Looks not so good if in passive state. Unfortunately that’s about as much as I’ve been able to glean. Perhaps a real metallurgist can comment. I have painted the aluminum Hinge Bracket first with Zinc Chromate and then gloss white urethane so chance of interaction is further reduced.
Zinc plated AN steel washer/bolt and aluminum looks like no problem.
Hinckley, Ohio
EAA #499867
Old 04-05-2018, 05:15 PM
Tony_T's Avatar
My take would be that by scuffing the SS washers and alum brackets and glueing them together the SS at the interface would stay in the active state. Especially if the assembly is primed. It looks like the aluminum would still be slightly sacrificial but for a corrosion cell to form there would have to be an electrolyte present.
Anxious to see where this thread goes...
Tony
