W-423 Joint Plate miss drill
Little Wing
Managed to drill a platenut hole in the wrong place(used wrong hole in jig tool). Spacing is 10/32. Anyone think I need to fab a doubler? I know some folks have added additional screws due to pillowing hanksof the tank skin and I am wondering how this would effect the repair?
Thanks!
http://i57.tinypic.com/20rtdux.jpg
I'm assuming screw hole is in the right place and the #40 hole on the left is the oops. If that's the case, I'd deburr it, then ignore it. Even if you want to go back and add screws in between, I think you're going to end up with plenty of edge distance.
