Old 11-22-2019, 03:26 PM
Bynan Bynan is offline
Default Minimum required tools for RV practice kit
After reading way too many forum posts and watching way too many YouTube videos, I have decided on a 12iS. But first I want to build the practice kit and the tookbox. However, I don't want to spend $1,000 in tools just for that, in case working on those discourages me, which I doubt, but still...
Can anyone point me to a list of the minimum required tools for accomplishing that task? And I mean a list with links to actual products on amazon or harbor freight or something? The Van's site has a list of tools with double asterisks by the ones needed for the practice kit, but it just says 'one 1/4" thingamabob'. If I don't really know what that thingamabob is, then it's hard to be sure I'm getting the right one.
Old 11-22-2019, 03:51 PM
Suggestion - find nearest EAA chapter. I'm sure tools can be borrowed for initial test build.
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 558
LSRM-A Certificate 2016 for RV-12 N633CM
Old 11-22-2019, 06:01 PM
Bob Y Bob Y is offline
Or take one of these courses. They’re great!
https://www.eaa.org/eaa/event/01-11-...30A6A3AFF28D65
Bob Y - builder 12iS
N569TT first flight 2/9/2020
Old 11-22-2019, 06:04 PM
Default Welcome to VAF
Bryan, welcome to VAF-----and congrats on your choice of planes.
Second to the EAA suggestion.
Old 11-22-2019, 06:51 PM
E. D. Eliot E. D. Eliot is offline
Default Tool
My most important 'tool' was a man who offered to help me get started. I am a very handy guy who has built houses and serviced a few autos and that didn't even qualify me to do an acceptable job on my RV-12 without help. Never worked with metal or fiberglass. My helper got me started off right including which tools to buy.
Go to an airport nearby, walk around, and look for someone who has an RV. Chances are good that that person will help you get started or direct you to someone who is currently building an RV. Helping someone else build his RV will get you started off well. You will see what it takes to work on an RV and then you may decide either to build or not build. You will find this out after only a few sessions wherein you help build the other persons RV. PM me if you would like to discuss this on the phone.
Building finally
Old 11-22-2019, 07:00 PM
wirejock's Avatar
wirejock wirejock is offline
Default Mentor
Agreed. You could also look up the nearest EAA Chapter, attend a meeting and ask around for a Mentor. Build one or both of the practice kits together, drill them apart and reassemble. By then, youll have a really good handle on which tools you want/need.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/03/2019, plus a little extra.
Disclaimer
Old 11-22-2019, 07:30 PM
DRMA DRMA is offline
I agree fully with both the recommendation to find someone to mentor your practice kit and to look for one of the EAA Sport Air workshops to get a good start on building.
Also, you should be aware that the practice kits use mostly solid rivets that are driven or squeezed, while I believe the RV-12 is mostly pulled rivets, so easier to put together. You might consider ordering some pulled rivets with the practice kit and substitute them to get a better idea of how the RV-12 will be built. A phone call or email to Van's builder assist may find someone to help you determine the best rivets to order to modify the practice kit.
Dave Macdonald
RV-10 First Flight April 1, 2020. Currently in Phase 1
2020 VAF Dues Paid
Old 11-22-2019, 08:14 PM
DaveLS DaveLS is offline
Second Larry’s idea,
Before even starting practice with scrap the following: Assemble, take apart, and reassemble. Taking apart is a required skill. Try doing the reassembly with different style rivets (solid vs pulled) and then take apart again. Intentionally over squeeze some solid rivets and see how the parts “pucker” apart.
By the way this will not be frustration free.
-Dave
Old 11-22-2019, 09:11 PM
brucehatch brucehatch is offline
Default What will it be like to build the -12iS
Bynan, consider taking the fundamental course from Synergy Air in Eugene, Or.
https://synergyair.com/
They are just one state up from you. You will get a very good idea of what building the -12iS is like from their one day class. They provide all the tools. I took the class before deciding to proceed with the project. Have no regrets. The other thing I did was attend Oshkosh for the first time. Wow, that was a real eye opener. Leaned a lot. Good luck.
Bruce
Working empennage kit
EAA Chapter 753, Provo, Ut.
Dues paid thru 2020
Old 11-22-2019, 09:52 PM
rapid_ascent rapid_ascent is offline
You can get by with minimal tools for a practice kit. There are many ways to do certain operations. Some of them are more time consuming than others. If you have any hand tools you probably have some of the tools that you will need. You can use a cordless drill for example until you decide you are committed to building more of the kits. I use some of the files I had previously for knocking off the punch marks before final sanding the parts edges. If you don’t have any files then just start with a little rougher sand paper and finish off with 220. The one thing you will probaby need is a hand rivet squeezer. I have a Tatco and really like it. There are clones too. Take a look at the yardstore.com they are very reasonable.
I would suggest you buy the kit and take it one step at a time. Just buy as you go. As others have mentioned take the EAA sheetmetal course and that will get you started. With the course they provide the tools and show you the correct technique. They give up in Wattsonville but maybe there is a place closer to you down in SoCal.
Also most builders would probably be willing to help you build a practice kit if you can track down a builder local to you.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
