Old 11-22-2019, 03:11 PM
iaw4 iaw4 is offline
Default Transparent Vinyl Over Polish?
Is it possible to put a transparent vinyl wrap over the polish to preserve the mirror look but avoid the needed regular aluminum polishing maintenance?
Old 11-22-2019, 09:03 PM
Flyfish Flyfish is offline
I put a good wax on after I polish. Lasts a long time.
Old 11-23-2019, 09:13 AM
what's a long time? 5 years or 5 months?
(which wax?)
Old 11-23-2019, 09:16 AM
Snowflake's Avatar
If you're willing to wrap anyway, maybe consider chrome vinyl.
Rob Prior
Old 11-23-2019, 05:14 PM
Ralph Inkster Ralph Inkster is offline
Vinyl sticks good to bare aluminum, painted surfaces, and pretty good to alodyned surfaces. I know there are some primer brands that vinyl will not stick to. I suspect it wouldn't stick to well to polish either, but haven't tested this.
I suggest you do a test panel.
Ralph
It's time to work on just my own planes, not everybody else's...
Old 11-23-2019, 05:57 PM
emsvitil's Avatar
emsvitil emsvitil is offline
This is what I thought of happening (eventually) if you did cover with clear
http://www.vansairforce.com/communit...d.php?t=177045
Ed
Old 11-23-2019, 08:39 PM
Sorry. I should have been more specific. I polish once per year. Then I follow up immediately with a wax. I use a polymer type car wax. Which by the way will slightly dull your fresh polish job. But I value the protection it gives. Then I will use a spray wax throughout the year just to clean it up. I can get though the year no problem and I suspect I could go two years if I wanted. But I'm on the coast near Oregon so I'm in worst possible environment.
Old 11-24-2019, 09:22 AM
Snowflake's Avatar
Unlike the UHMW tape used on the flaps, the vinyl adhesive is designed with later removal in mind.
Rob Prior
Old 06-27-2020, 05:18 PM
Potato Potato is offline
Has anyone tried this?
https://www.orafol.com/en/europe/pro...one-guard-film
Old 06-29-2020, 06:39 PM
rcsilvmac rcsilvmac is offline
You might want to try John's 360 Ceramic Coating. I have heard that this coating works well over polished aluminum. I don't have personal knowledge, but give him a call! I love the coating on my painted plane.
2020 Dues paid
RV-6A
