Go Back   VAF Forums > RV Firewall Forward Section > Traditional Aircraft Engines
Old 04-09-2019, 08:04 AM
Rbb469 Rbb469 is offline
Default Spark plug adapters- If youíre in need of read below.
I just purchased spark plug adapters from Protek performance, Inc out of California. Extremely prompt courteous service and fast shipping. Machined in house. A package of 8 for $133.00 shipped to my house. Give these guys a try. www.FlyEFII.com 951.317.3473
Dues gladly paid!
Old 06-18-2019, 09:43 AM
sdflier sdflier is offline
Default Another good source:
www.brillman.com
Part number B9005-002 (18mm to 14mm solid brass adapter)
$9 each
Craig Hagen
RV-6A N289CH flying 1000+ hours
2019 dues paid
Old 06-18-2019, 11:05 AM
isosceles isosceles is offline
are they any good?
Old 06-18-2019, 03:35 PM
vetterman vetterman is online now
Default Reducers
Iíve been using Brillman reducers for at least 15 years and have installed then on at least 12 planes. So yes theyíre good. Iíve never told them what I was using them on, but if they ever ask, it would be for my Allis Chalmers tractor.
Old 06-18-2019, 04:51 PM
DanH's Avatar
DanH DanH is offline
To be frank, I ordered a set of Brillman adapters and sent them back. I'm sure they will work, but they were not as good as adapters from EFII and SDS.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-19-2019, 10:49 AM
smokyray's Avatar
smokyray smokyray is offline
Default Not to reason...
Glad U like them but...
I never liked adapters, so I use Denso L14U or Autolite 386 plugs. 25 years on they still work great on my Electroair/ P-Mag's and thread right in.
V/R
Smokey
Old 07-03-2019, 06:42 PM
N333M's Avatar
N333M N333M is offline
Default Autolite 386
Smokey,
Hold on a sec..You mean this Autolite 386 18mm plug will work for our Lycomings?..I have a carbed 0-320..160 hp mods..???
I just looked it up and these things are 1.99 at AutoZone!!.. I realize a harness change would be in order..but it the heat range comparable?..are you running them in an lycoming? Im pretty interested in this!!
Don
D. Gherardini
Central Illinois
RV9A slider 0-320 carbed
Kitfox IV (SOLD)
Luscombe 8A (SOLD)
Old 07-03-2019, 07:09 PM
I just swapped out my Denso plugs for 386's on my Lightspeed system. At annual (just bought the plane) I found one of the Denso-s about 2/3s of the way backed out of its adapter. Decided the 386s were too easy a solution.
Old 07-03-2019, 11:44 PM
SHIPCHIEF SHIPCHIEF is offline
I'm currently trying Champion stock # 526, RD15Y on my RV-8 Parallel valve O-360, 8.5:1 . It's an 18mm resistor plug like the Autolite 386, but also has a projected tip. I'm hoping it's slightly cooler, but I only have a few hours on them, trying both high power, and very low power flight. I won't know much until something happens or it's oil change time and I pull the plugs for a look.
3.99 ea thru Summitracing.com
I also have successfully used Autolite 386 on my Thorp T-18. They stay clean and do not show heat stress on my O-290 with 7:1 compression.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 07-04-2019, 05:44 AM
Fly2KiteSurf Fly2KiteSurf is offline
Default Why does e-mag recommend adaptors?
Hello all,
Why do the P-mag folks recommend using adaptors in lieu of using 18mm plugs?
A couple years ago I had a conversation with them at Sun-n-fun, and they reccomended against 18mm plugs.
For me, it's all about safety, not cost or complexity of maintenance, etc...
Sean.
Sean Reynolds
Purchased RV-3 project, restored, flew for 18 months, sold. Purchased flying RV7, flew for 5 years, sold. Currently building RV-14 quick build.
