Go Back   VAF Forums > Main > RV Ongoing Maintenance Issues
Old 10-13-2018, 09:24 AM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
Originally Posted by Speedbird1 View Post
Thanks for posting this. I appreciate it. You are using the Dynon Capacitance to voltage converter, correct? Also, do your plate look like this:
https://www.dropbox.com/s/eihqsho9e4...40018.jpg?dl=0
Yes, to the Dynon converter and as I remember yes to the plates. Itís been 8 years since I built my tanks, I used Vanís plate kit. And the Dynon converter from 6 years ago. So things could have changed.
One note: after the second calibration, I was still not quite happy with the gauge readings, so I made some manual adjustments to the numbers you see. It took some time, tracking fuel burn, dip sticking before and after each flight, writing a log. And I was also adjusting the Dynon for the red cube fuel flow, that was easier.
Bruce, Katie, Hana and RV-8 HulaGirl
Old 10-13-2018, 02:49 PM
Speedbird1 Speedbird1 is offline
Thank you for the help, Bruce. It's very much appreciated.
