Go Back   VAF Forums > Main > RV Ongoing Maintenance Issues
Old 02-13-2018, 10:52 AM
FasGlas's Avatar
FasGlas FasGlas is offline
It's a good racket for them, just like Garmin, a quick fix is $225 and big fix is $225. Just slap on a few bucks worth of ear cups and a pad and you have a $400 set of Bose X that you just paid $225 to replace a $2 plastic yoke. Sounds a bit like Apples business model... New model about to be released and Apple send out a "Slow down" bit of software to everyone's existing Apple.. UPGRADE..
Old 02-13-2018, 11:36 AM
Aluminum Aluminum is offline
Then again, I pay a Bose a month to rent a rusty hangar older than I am that floods whenever it rains. I find that when a company gets this successful, it's usually because the price is worth it, not because they're all evil greedy capitalists.
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
2018 dues worth every penny
Old 02-13-2018, 11:54 AM
FasGlas's Avatar
No, I find that as a company becomes the best game in town their customer service tends to become distant a greedy. Garmin used to have a decent customer service and a reasonable price a long time ago but then refused to deal with the aircraft owners, since then all TSO'd equipment must go through a dealer and the price rocketed.. And dealers charge you, too. The bigger Garmin got the worse they treated us. Bose aviation are pretty much top of the line, they know it, and it's a very small part of their business. Treating us like ATM's is their model. Lightspeed did the same thing. Apple is the same, probably one of the greediest of them all. I do my best trying not to support companies like these but sometimes you have little choice.
A prime example is this broken yoke, just a few bucks, and very easy to change out. Yet, Bose demands $225 to do just that and they will not sell any parts. Garmin charges a full service fee to replace a worn out backup battery. Go look at the service fee schedule for Garmin. YIKES!! The battery is about 5 bucks. (I change my own, takes about 20 minutes).
Old 02-14-2018, 07:00 AM
Michael Henning Michael Henning is offline
A yoke broke on my Bose X headsets. I upgraded to the DC One-X and haven’t looked back. Less money, equal or better performance, and if it breaks, I can drop it off to DC in the morning and they will fix it same day for free! It was a no brainer for me, plus the Bluetooth is great on X-country flights.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 02-14-2018, 07:55 AM
SgtZim SgtZim is offline
Originally Posted by ArVeeNiner View Post
They charge $225 for a full refurbishment.
ow, time to mix up some epoxy then
I hope you can get them back into service.
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 02-14-2018, 09:32 AM
Epoxy? Go one better... JB Weld!
Last week I discovered my wife's Bose X had a broken yoke. Don't know what broke it - suspect it just gave up the ghost with all the thermal cycling it's been seeing of late.
Brought the headset home, removed the wire clip and pulled the wire from the yoke, then scuff-sanded the plastic to give some "tooth" for adhesion. Mixed up a batch of JB Weld, applied and let cure 48 hours. Reinstalled the wire and wire clip.
Looks a bit less appealing than a new yoke, but on Monday's flight it worked a charm. Net cost of the repair was likely $0.25...
If it breaks again I'm going to pull the wire from its track within the yoke, then cut and fit a piece of steel wire (small coat hanger) and JB-Weld it into the wiring track. The wire itself will be tacked to the JB-Weld using cyano-acrylic glue.
While I like the Bose, I'm not at all inclined to spend the CAD$300 it would take for a factory repair. I contrast this to my David Clarks which I purchased new in 1980 - I've suffered one microphone failure with them and no wiring or mechanical failures in 37 years or service. Bose would do well to revisit the mechanical design of their headsets. The ear cup yoke clearly is not the place to use plastic as the primary structure.
Old 02-14-2018, 11:00 AM
Canadian Joy is right about the build structure of Bose headsets. Mine broke trying to replace the ear pads, and I was being gentle. The DC headsets are built more than strong enough to handle occasional abuse.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 02-21-2018, 09:45 AM
ArVeeNiner's Avatar
ArVeeNiner ArVeeNiner is offline
Default Thumbs up for Zachary!
OK, I received the replacement yoke from Zachary (see a post above for contact info) and installed it last night. It fits well and I'm very satisfied. The new part required no preps on my part except for running the three screws in first so that they can cut threads.
Note, one of the screws on the headset is a real PITA. It must be the world's smallest Torx fastener and it holds a tiny bracket down which secures the headset cable to the yoke. I thought I had just about every size Torx driver made but I only go down to a size 6. I finally got it out using a tiny jeweler's flat bladed screw driver. Getting it in was a pain as well. After dropping the tiny thing a number of times onto the floor I finally had success when I ran one of the other larger screws into this hole just to open it up a little bit.
The finish of the replacement yoke looks a little different than the original so you can tell it's a replacement if you look close but that doesn't bother me at all. I was also surprised that the new yoke had a small raised L on it (for left) just like the original.
Zachary's communications were great and it was shipped out quickly. For $27 my Bose X headset is back up and running. Now I want to change the ear pads!
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
First flight: 5/28/12, Memorial Day.
Phase I Complete: 8/18/12!
2019 donation: complete
Old 02-21-2018, 09:57 AM
FasGlas's Avatar
Thanks for the Pirep... I have been holding on to Zach's information just in case someone needed one of those yokes, and if I needed one. As for the ear pads, they can be bought on ebay for very cheap, they come as a complete set with the screens. I've used them a few times. Just like new and you saved a few hundred $.
Old 02-21-2018, 10:15 AM
ArVeeNiner's Avatar
I'll take a look. Thanks!
Kelly Johnson
San Jose, CA
RV-9A
