GDU 470 Portrait 7” G3X Touch Display
We’re excited to announce the GDU 470 portrait G3X Touch display with the same great features as the 10.6” and 7” landscape G3X Touch displays, including advanced integration with Garmin G3X autopilot, transponders, radios, audio panels, and more. This frequently requested form factor now offers even more flexibility to design your ideal panel. Mix and match up to 4 G3X Touch displays in a single aircraft to suit your needs. The new display is expected to be available in Q2 of this year for
$2,995 minimum advertised price (MAP) with an optional remote mount SXM module coming later this year.
In addition to offering more flexibility for new installations, the GDU 470 offers an easy upgrade path for first generation G3X customers. All displays in the G3X Touch family are fully pin compatible with the GDU 370 G3X displays and all of the installed remote mount and complimentary components can stay in the aircraft unchanged.
The GDU 470 outer dimensions are nearly identical to the GDU 370 dimensions. However, to help ease the transition from the GDU 370 to GDU 470 display, a steel drilling guide will also be available. Simply attach the drilling guide using the existing GDU 370 nutplate holes, drill new holes for the GDU 470 mounting screws and slightly enlarge the corners of the existing GDU 370 hole. Mount the GDU 470 and reuse the existing 50 pin d-sub connector. One of the less obvious benefits of upgrading to the new displays is you get 6 serial ports instead of the 3 on the GDU 37X series displays which gives you even more options to integrate complimentary hardware such as the GMC 307 autopilot controller. Please keep in mind that you cannot mix and match first generation G3X displays with G3X Touch displays.
GMU 11 Magnetometer
The new GMU 11 magnetometer is lighter weight and allows for more flexible installation than the previous generation magnetometer. It can be mounted in any of the four cardinal directions and is a CAN bus connected device capable of providing magnetic heading for original G3X, G3X Touch, and standalone G5 installations. Up to two GMU 11 magnetometers can be installed on the CAN bus for additional redundancy if desired. The GMU 11 will be sold for $275 MAP when purchased separately or as a supplemental magnetometer, but is also kitted with the core LRU kits (see next section for details). Additionally, the GMU 11 will be PMA’d and will enable our G5 electronic flight instrument to act as a DG/HSI replacement in 600+ models of certified aircraft. Read more about those updates in our press release
here. Availability Q2 2017.
Simplified Pricing Structure
Finally, we are introducing a new more builder friendly pricing structure making it easier to buy components that match the stage of your build. Previously, displays were kitted with all the core system LRUs and we are excited to offer customers more flexibility with this a la carte approach.
The diagram below provides a quick overview of the new process. As an example, you can order your LRU kit and install the core remote mount pieces while you are working on the wings and fuselage. Then purchase your displays when you’re ready to build the panel. If you have a high-performance aircraft (exceeding 300 KIAS), be sure to purchase the high performance LRU kit.
As usual, if you have any questions, feel free to contact us directly using the information in the signature line below. Or come see the new display at SNF! We’d love to talk to you in person.
Brian
