Louavul
Attempting to install a Bendix mag in the right position on my recently assembled ECI O-360 A1A. This mag does not have an impulse coupling.
It looks as though this mag will bolt directly to the accessory case as that gives me full gear interface with the idler however, this allows for too much stud preventing the nuts from being run down. With the impulse coupling spacer installed the studs are just the right length but, there is no contact with the idler.
So, question is, do I need a longer mag drive gear to use with the spacer (IPC shows spacer installed) or shorter studs when the spacer is removed and the mag is attached directly to the accy case?
Neither my IPC or Overhaul manual addresses this or I haven't found it yet. I have found a SB that allows for a different spacer/drive but, it doesn't seem to be for my specific engine, cost of which gives me the creeps.
