I'm trying to figure this out, as I'm building a remote oil filter assembly and want to use a small after market oil temp sensor on the filter housing. Chief Aircraft offers a sensor in 1/8" npt (pipe thread) and an adapter to fit it to the 5/8"-18 port on the oil filter or strainer housings.
http://www.chiefaircraft.com/iss-dcn0201700k.html but does not state the resistance. It's an ISS brand, I think using the Stewart Warner system?
Temperature Senders, I think Lycoming uses the:
? Stewart Warner Scale
? 800-33 ohm
? 0 to 250?F
Oil Pressure Sender
? 240-33 ohm
? 0 to 100 psi
The temperature and pressure gages use variable resistance and Stewart Warner was the standard back in the day.
Van's sells an oil temp sensor with a part number that matches:
Temperature Sender 100-240F by Datcon p/n 02017-00.
For oil pressure senders, PN 411K, Scott McDaniels from Van's states: The normal resistance of this sender is the standard 30 - 240 (same as many of the other sensors such as fuel level, etc.) (240ohm at 0psi, 33.5ohm at 100psi)
It is normal for them to have a measured value that is off by a few ohms at one end of the range or the other.
