David Paule
Now that I've built four of these things, here's the sequence of steps that seems to work best. There might be other steps to consider - for example, I had to open up the trailing edge bend to drill and rivet the stiffeners and then had to rebend it. I also had to tighten up the leading edge radius a bit, too.
The plans said to use a flat table, but I use a couple of vee blocks, carefully aligned, just like I did when I was building the tail control surfaces. The vee blocks are also used for the flaps. It's a simple way if ensuring straightness.
Drill spar flange to top skin
Stiffener - Dimple
Stiffener - Prime
Stiffener - Rivet
Drill the spar's lightening holes
Rivet reinforcement plates to spar
Drill nose ribs to spar
Remove nose ribs, drill main ribs to spar
Cut access holes in inboard main ribs
Drill pipe to nose ribs -- manual says to spar.
Prime pipe.
Rivet pipe to nose ribs
Rivet nose/main ribs to spar
Break bottom-most edge of skin
Place in jig
Tape and clamp skin in place
Locate bottom spar holes
Check
Drill (#40) bottom skin and spar, cleco
If the leading edge radius needs rebending, do it now
Drill skin for end ribs
Drill pipe balance and skin
Disassemble, prime and deburr and dimple
Rivet top of spar to skin
Clean out any debris from interior
Replace in jig
Blind rivet (CS 4-4) the bottom of skin/spar
Rivet end ribs, pipe balance
Trim leading edge at outboard ends for hinges
Stiffener - Dimple
Stiffener - Prime
Stiffener - Rivet
Prime pipe.
Place in jig
Check
Replace in jig
