rag
I have a Skytec starter with the solenoid mounted on the starter (O360 RV4).The high current power cable runs from the master solenoid through the fire wall to the starter solenoid. This cable is ?hot? as long as the master is on. Are builders installing a 300 amp fuse on this cable at the master solenoid? Or mount a 300 amp fuse on the positive post at the battery before the master solenoid? Or no fuse in the either line? I have not been able to find any posts that address this. I?m a little uncomfortable not having any protection on either cable. I would like to know what others are doing. Thanks!!
