Wouldn't seem to make a difference
I agree that approximate quantities of Camguard to oil is good enough. Don't know why you would bother to carefully mix it with each quart when changing oil. As soon as you start the plane, the oil pump will mix it for you. It is really all about how Camguard sticks to surfaces longer after shutdown than what it does when the engine is running.
