Piper - Yes, I have installed a Matco parking brake on the right tunnel rib.
Am not flying yet, but mounting the Matco parking brake high on the right tunnel rib seems to be a good location for the parking brake ... and clear of the rudder cables.
You drill a second setting with the arms shorter and the prongs pointed up. This lets it be used as a control lock. It locks the flaperons, pitch, and rudder. The prongs press against both brake pedals and also act as a parking brake.
You can drill a third position to be just a flaperons - pitch - rudder lock without the brakes, by having the prongs press against just the rudder pedal.
One nice thing about this is that it locks the pitch in the neutral position, not full up pitch.
