yankee-flyer
OK, I've updated the D-180 to version 5.5 and installed the 15 psi Kavlico sensor with the recommended capacitor. At first the fuel pressure showed 69 pounds but after some research we found that the fuel pressure sensor TYPE should be set to 6. With that done it now reads 5.9 to 6.1 pounds with ONLY the electric pump running, which is right on the edge (and sometimes over) the alarm setting.
I'm open to ALL suggestions-- we've obviously missed something.
Gearbox and nosewheel parts are installed, waiting for prop blades
THANKS
Wayne 120241/143WM
THANKS
Wayne 120241/143WM
