RFSchaller
I've looked through the postings and can't find a specific answer as to how to rework the oil pressure sensor leads to replace a Honeywell unit with a Kavlico sensor. From the schematic it looks to me the Honeywell has a +12V lead, a signal lead and a ground while the Kavlico has a +5V lead, a signal lead and a ground. Can I simply connect the existing ground and signal leads and then splice into the +5V excitation from the MAP sensor in lieu of the +12V? My D180 manual isn't any help because it still shows the VDO unit as the sensor.
Rich
Rich
