jayapro123B
Member
The same day Vans posted S.B.13-12-19 my flowscan reading went to zero. Time to simplify. Look at revised 37-01 and notice the two floats and the absence of the sight gauge. My tank with 75 hours flying has the sight gauge, the front float, the S.B.11-12-14 completed and no mechanical float gauge.
S.B. 13-12-19 requires that I take the tank apart again and redo the reinforcements.
I think the better solution is to build a new tank with the new reinforcements per S.B.13-12-19. The new tank will not have the sight glass but will have the mechanical fuel gauge which makes redundant the front plate, sender and float wired into the dynon now unnecessary along with the broken flowscan.
I can put a fuel filter in place of the flowscan.
I called Vans and asked them if they would make me a T-1202 without the cutout. They said they would get back to me. New tank parts to include the mechanical fuel gauge, reinforcements, vent kit and a T-1202 without the hole in it is all I need to make a simple light weight tank.
I hope Vans recognizes that the two floats pictured in 37-01 appear redundant and my proposed solution will make a light weight and safe fuel tank.
